Okay I was just wanting to make sure we were on the same page. I have some strange experiences on these sites.
Thanks I gotcha!![]()
This is a great site. Ask any questions until you uderstand and are sure what to do.
Hello umm still have the issue Java is stuck and wont move.
Sorry that you still have the problem
Make a full anti virus scan
Download and make a full scan with Malarebytes.
Make sure that you have enough memory. (give me a screen shot of task manager and performance tab.
Here is the screen shot wow memory is getting eaten. I also ran the anti virus scan the other day...
Run the Malwarebytes, too.
Make sure the A/V was updated when you did the scan and that it was the full scan. Ditto for Malwarebytes.
Looking at your memory, I see you have 2 GB, Flash Player uses a lot of RAM. I think its a memory problem.
Make a clean boot and follow the procedure. If everything works in clean boot, you either have a conflict with software (procedure will tell you which one) or not enough
memory.
Troubleshoot Application Conflicts by Performing a Clean Startup - Windows 7 Forums
Okay I did what you have said. I am not sure what I am really suppose to be doing. Did you want me to try and download Java or delete old Java after doing the above?
I am not sure what you mean it might be a hardware problem.
The only things that you should be doing now
Is run a full anti virus scan
Run a full scan with Malarebytes. These scans would take around an hour.
If they are negative. Do the clean boot.
| Similar Threads | ||||
| Couple of Niggles - Help Please | Young Mandy | Vista mail | 1 | 04 Mar 2007 |
| Couple Of Niggles - Help Please | Young Mandy | Vista mail | 0 | 04 Mar 2007 |
| A couple of questions | Drew | Vista General | 3 | 23 Feb 2007 |
| Couple of Problems - HELP!! | Gaxor | Vista General | 0 | 06 Feb 2007 |
