Cpu replacement need Help
sphwhat316
i have a gateway one it came with Intel® Core™2 Duo Processor1 T5250 (1.50GHz, 667MHz FSB, 2MB L2 Cache) and would like to know on newegg which is the best to get that is more powerful than this? also the motherboard is Systemboard w/ Intel® GM965 chipset
Hi sphwhat316 and welcome to the forums :party:
What is the model number of your computer?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
