The dump file points to your Ralink 802.11n Wireless Adapter Driver as being at fault.
Update that to see if it fixes it.
Probably caused by : netr28u.sys ( netr28u+ba7f )
There are some older drivers on your system that may also be contributing to this. Try updating them if updating the Ralink drivers doesn't work:
Code:
8d718000 8d727000 VMNetSrv VMNetSrv.sys Wed Jan 24 07:05:29 2007 (45B74B89)
8d7f6000 8d7fa880 hamachi hamachi.sys Wed Aug 15 19:05:00 2007 (46C3869C)
8f2d0000 8f30b000 vmm vmm.sys Sun Feb 18 03:10:42 2007 (45D80A02)
8f55d000 8f5b2000 netr28u netr28u.sys Mon Apr 02 10:59:39 2007 (46111A5B)
Here's the memory dump:
Code:
Loading Dump File [C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18005.x86fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0x82239000 PsLoadedModuleList = 0x82350c70
Debug session time: Sun Jul 5 23:58:18.307 2009 (GMT-4)
System Uptime: 0 days 0:51:09.221
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck D1, {8, 2, 0, 8f568a7f}
Unable to load image \SystemRoot\system32\DRIVERS\netr28u.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for netr28u.sys
*** ERROR: Module load completed but symbols could not be loaded for netr28u.sys
Followup: MachineOwner
0: kd> !thread;!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;.logclose;q
GetPointerFromAddress: unable to read from 8237086c
THREAD 82335640 Cid 0000.0000 Teb: 00000000 Win32Thread: 00000000 RUNNING on processor 0
Not impersonating
GetUlongFromAddress: unable to read from 82348394
Owning Process 82335900 Image: <Unknown>
Attached Process 8405c490 Image: System
ffdf0000: Unable to get shared data
Wait Start TickCount 17305
Context Switch Count 2861799
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime 00:00:00.000
KernelTime 00:00:00.000
Win32 Start Address nt!KiIdleLoop (0x822e1834)
Stack Init 8232f000 Current 8232ed4c Base 8232f000 Limit 8232c000 Call 0
Priority 0 BasePriority 0 PriorityDecrement 0 IoPriority 0 PagePriority 0
ChildEBP RetAddr Args to Child
8232ea5c 8f568a7f badb0d00 8680b008 00000808 nt!KiTrap0E+0x2e1 (FPO: [0,0] TrapFrame @ 8232ea5c)
WARNING: Stack unwind information not available. Following frames may be wrong.
8232eacc 00000000 00000246 00000000 00000000 netr28u+0xba7f
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000008, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 8f568a7f, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 82370868
Unable to read MiSystemVaType memory at 82350420
00000008
CURRENT_IRQL: 2
FAULTING_IP:
netr28u+ba7f
8f568a7f ?? ???
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: 8232ea5c -- (.trap 0xffffffff8232ea5c)
ErrCode = 00000000
eax=00000000 ebx=00000001 ecx=8680c000 edx=8680b008 esi=797616b0 edi=8232eb94
eip=8f568a7f esp=8232ead0 ebp=8232eae0 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
netr28u+0xba7f:
8f568a7f ?? ???
.trap
Resetting default scope
LAST_CONTROL_TRANSFER: from 8f568a7f to 82286fb9
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
netr28u+ba7f
8f568a7f ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: netr28u+ba7f
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: netr28u
IMAGE_NAME: netr28u.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 46111a5b
FAILURE_BUCKET_ID: 0xD1_netr28u+ba7f
eax=82331920 ebx=00000002 ecx=82339200 edx=000000b1 esi=8233193c edi=00000000
eip=82286fb9 esp=8232ea44 ebp=8232ea5c iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000206
nt!KiTrap0E+0x2e1:
82286fb9 833d847c368200 cmp dword ptr [nt!KiFreezeFlag (82367c84)],0 ds:0023:82367c84=????????
start end module name
8060e000 80615000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
80615000 80685000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
80685000 80696000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
80696000 8069e000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
8069e000 806df000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
806df000 807bf000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
807bf000 807fe000 HdAudio HdAudio.sys Sat Apr 11 00:43:01 2009 (49E01FD5)
82206000 82239000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
82239000 825f2000 nt ntkrpamp.exe Sat Apr 11 00:16:30 2009 (49E0199E)
87e04000 87e80000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
87e80000 87e8d000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
87e8d000 87f8d000 sptd sptd.sys Wed Mar 05 19:32:57 2008 (47CF3BB9)
87f8d000 87f96000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
87f96000 87fbc000 SCSIPORT SCSIPORT.SYS Sat Jan 19 00:49:44 2008 (47918F78)
87fbc000 87ff1000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
88004000 8804a000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
8804a000 88052000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
88052000 88079000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
88079000 88088000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
88088000 88097000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
88097000 880e1000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
880e1000 880e8000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
880e8000 880f6000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
880f6000 88106000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
88106000 8810e000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8810e000 8812c000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
8812c000 8815e000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
8815e000 8816e000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
8816e000 881bd000 SYMEFA SYMEFA.SYS Wed Feb 04 20:06:37 2009 (498A3B9D)
881bd000 881e7000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
88200000 88271000 ksecdd ksecdd.sys Sat Apr 11 00:30:03 2009 (49E01CCB)
88271000 8837c000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
8837c000 883a7000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
883a7000 883e2000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
883e2000 883ef000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
883ef000 88400000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
88402000 884ea000 tcpip tcpip.sys Sat Apr 11 00:46:42 2009 (49E020B2)
884ea000 88505000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
88505000 88514000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
88514000 885b3000 dxgkrnl dxgkrnl.sys Sat Apr 11 00:23:43 2009 (49E01B4F)
885b3000 885c8000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
885c8000 885d8000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
885d8000 885e3000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
885e3000 885ed500 WmXlCore WmXlCore.sys Thu Jan 24 18:01:03 2008 (479918AF)
885ee000 885f8000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
88609000 88719000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
88719000 88752000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
88752000 8875a000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
8875a000 88769000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
88769000 88790000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
88790000 887a1000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
887a1000 887c2000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
887c2000 887cb000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
887eb000 887f6000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
887f6000 887ff000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
8d601000 8d68e000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8d68e000 8d6a8000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
8d6a8000 8d6b2000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
8d6b2000 8d6ca000 parport parport.sys Sat Jan 19 00:49:32 2008 (47918F6C)
8d6ca000 8d6e2000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
8d6e2000 8d718000 aa8rjdii aa8rjdii.SYS Wed Dec 03 13:18:18 2008 (4936CD6A)
8d727000 8d756000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
8d756000 8d797000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8d797000 8d7a2000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
8d7a2000 8d7b9000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8d7b9000 8d7c4000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8d7c4000 8d7e7000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8d7e7000 8d7f6000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8d7fb000 8d7fc380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8d7fd000 8d7ff680 vmnetadapter vmnetadapter.sys Thu May 22 06:33:07 2008 (48354BE3)
8da00000 8da0b000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8da0c000 8e37cd20 nvlddmkm nvlddmkm.sys Wed Jun 10 10:17:13 2009 (4A2FC069)
8e37d000 8e37e080 nvBridge nvBridge.kmd Wed Jun 10 09:38:05 2009 (4A2FB73D)
8e37f000 8e38b000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8e38b000 8e396000 usbuhci usbuhci.sys Sat Jan 19 00:53:20 2008 (47919050)
8e396000 8e3d4000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8e3d4000 8e3e3000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8e3e3000 8e3f7000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8e3f7000 8e3fa180 WmBEnum WmBEnum.sys Thu Jan 24 18:01:12 2008 (479918B8)
8e3fb000 8e3fdf00 VMNET VMNET.SYS Thu May 22 06:33:05 2008 (48354BE1)
8e802000 8e82f000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
8e82f000 8e854000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
8e854000 8e85d000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
8e85d000 8e864000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
8e864000 8e86b000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
8e874000 8e87a380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8e87b000 8e887000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
8e887000 8e8a8000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8e8a8000 8e8bf000 usbccgp usbccgp.sys Sat Jan 19 00:53:29 2008 (47919059)
8e8bf000 8e8c0700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
8e8c1000 8e8ca000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
8e8ca000 8e8da000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
8e8da000 8e8e1080 LHidFilt LHidFilt.Sys Fri Dec 19 02:37:23 2008 (494B4F33)
8e8e2000 8e8ea000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
8e8ea000 8e8f2000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
8e8f2000 8e8f9800 LMouFilt LMouFilt.Sys Fri Dec 19 02:37:27 2008 (494B4F37)
8e8fa000 8e902000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
8e902000 8e90d000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
8e90d000 8e91b000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
8e91b000 8e924000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
8e924000 8e93a000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
8e93a000 8e96d700 SYMTDI SYMTDI.SYS Mon Feb 02 18:50:52 2009 (498786DC)
8e96e000 8e993000 SYMEVENT SYMEVENT.SYS Wed Feb 11 17:21:00 2009 (49934F4C)
8e993000 8e9a4e00 usbaudio usbaudio.sys Sat Apr 11 00:42:54 2009 (49E01FCE)
8e9a5000 8e9b9480 SYMFW SYMFW.SYS Mon Feb 02 18:51:14 2009 (498786F2)
8e9ba000 8e9ce000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
8e9ce000 8e9e1000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
8ec09000 8ede6700 VX3000 VX3000.sys Wed Feb 20 06:14:17 2008 (47BC0B89)
8ede7000 8edf3f00 STREAM STREAM.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
8edf4000 8ee00000 SYMNDISV SYMNDISV.SYS Mon Feb 02 18:54:11 2009 (498787A3)
8f200000 8f20a000 ndisuio ndisuio.sys Sat Jan 19 00:55:40 2008 (479190DC)
8f20d000 8f255000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
8f255000 8f287000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
8f287000 8f290000 ws2ifsl ws2ifsl.sys Sat Jan 19 00:56:49 2008 (47919121)
8f290000 8f2a6000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
8f2a6000 8f2af000 SymIMv SymIMv.sys Wed Dec 03 19:01:24 2008 (49371DD4)
8f2af000 8f2bd000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
8f2bd000 8f2d0000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
8f30b000 8f314080 SRTSPX SRTSPX.SYS Wed Feb 11 23:31:31 2009 (4993A623)
8f315000 8f351000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
8f351000 8f35b000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
8f35b000 8f3a7000 IDSvix86 IDSvix86.sys Wed Jan 21 20:47:09 2009 (4977D01D)
8f3a7000 8f3c2000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
8f3c2000 8f3d2000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
8f3d2000 8f3fc000 nwifi nwifi.sys Sat Apr 11 00:43:27 2009 (49E01FEF)
8f408000 8f40e000 vmnetbridge vmnetbridge.sys Thu May 22 06:33:38 2008 (48354C02)
8f40e000 8f46c000 eeCtrl eeCtrl.sys Fri Feb 06 14:39:34 2009 (498C91F6)
8f46c000 8f489000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri Feb 06 14:39:35 2009 (498C91F7)
8f489000 8f4a0000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
8f4a0000 8f51b000 ccHPx86 ccHPx86.sys Tue Feb 17 16:20:36 2009 (499B2A24)
8f51b000 8f55d000 BHDrvx86 BHDrvx86.sys Tue Jan 27 18:23:38 2009 (497F977A)
8f5b2000 8f5bb000 kbdhid kbdhid.sys Sat Apr 11 00:38:40 2009 (49E01ED0)
8f5bb000 8f5bf080 VMkbd VMkbd.sys Thu Mar 26 23:59:48 2009 (49CC4F34)
8f5c0000 8f5cd000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8f5cd000 8f5d8000 dump_dumpata dump_dumpata.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8f5d8000 8f5e0000 dump_atapi dump_atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8f5e0000 8f5ea000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
8f5ea000 8f5f9000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
972f0000 974f2000 win32k win32k.sys unavailable (00000000)
97510000 97519000 TSDDD TSDDD.dll unavailable (00000000)
97530000 9753e000 cdd cdd.dll unavailable (00000000)
9bc0d000 9bcbd000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
9bcbd000 9bcda000 srvnet srvnet.sys Sat Apr 11 00:15:01 2009 (49E01945)
9bcda000 9bcf3000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
9bcf3000 9bd08000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
9bd08000 9bd29000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
9bd29000 9bd48000 mrxsmb mrxsmb.sys Sat Apr 11 00:14:27 2009 (49E01923)
9bd48000 9bd81000 mrxsmb10 mrxsmb10.sys Sat Apr 11 00:14:34 2009 (49E0192A)
9bd81000 9bd99000 mrxsmb20 mrxsmb20.sys Sat Apr 11 00:14:28 2009 (49E01924)
9bd99000 9bdc0000 srv2 srv2.sys Sat Apr 11 00:15:02 2009 (49E01946)
9c609000 9c655000 srv srv.sys Sat Apr 11 00:15:17 2009 (49E01955)
9c655000 9c65f000 hcmon hcmon.sys Thu Mar 26 21:51:53 2009 (49CC3139)
9c65f000 9c666000 parvdm parvdm.sys Sat Jan 19 00:49:28 2008 (47918F68)
9c666000 9c671c80 vmci vmci.sys Thu Mar 26 21:20:49 2009 (49CC29F1)
9c672000 9c674000 VMparport VMparport.sys Thu Mar 26 21:19:57 2009 (49CC29BD)
9c674000 9c743b80 vmx86 vmx86.sys Fri Mar 27 00:27:32 2009 (49CC55B4)
9c744000 9c7af000 HTTP HTTP.sys Sat Apr 11 00:45:29 2009 (49E02069)
a2e03000 a2ee1000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
a2ee1000 a2eeb000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
a2eeb000 a2ef7000 tcpipreg tcpipreg.sys Sat Apr 11 00:46:06 2009 (49E0208E)
a2ef7000 a2efbc80 vmnetuserif vmnetuserif.sys Thu Mar 26 22:04:43 2009 (49CC343B)
a2efc000 a2effd80 vstor2_ws60 vstor2-ws60.sys Mon Dec 01 14:26:30 2008 (49343A66)
a2f00000 a2f16000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
a2f16000 a2f68000 SRTSP SRTSP.SYS Wed Feb 11 23:29:04 2009 (4993A590)
a3605000 a36d9440 NAVEX15 NAVEX15.SYS Thu Feb 12 18:37:39 2009 (4994B2C3)
a36da000 a36ee1e0 NAVENG NAVENG.SYS Thu Feb 12 18:38:15 2009 (4994B2E7)
a36ef000 a36f8000 asyncmac asyncmac.sys Sat Jan 19 00:56:29 2008 (4791910D)
a36f8000 a36f9f80 WmVirHid WmVirHid.sys Thu Jan 24 18:00:59 2008 (479918AB)
Unloaded modules:
a36fa000 a3702000 drmkaud.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
8f400000 8f408000 drmkaud.sys
Checksum: 00000000
887cb000 887d8000 crashdmp.sys
Checksum: 00000000
887d8000 887e3000 dump_ataport
Checksum: 00000000
887e3000 887eb000 dump_atapi.s
Checksum: 00000000
8e86b000 8e874000 kbdhid.sys
Checksum: 00000000
Unloaded modules:
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Bugcheck code 000000D1
Arguments 00000008 00000002 00000000 8f568a7f
