Blue Screen Problem
  1. #1
    Vista Business 32bit
    Local Time: 08:26 AM
    Blue Screen Problem
    My pc crashes seemingly at random points in the day, this morning it crashed 3 times and has not since. The info at blue screen is as follows:
    STOP: 0x000000D1 (0x83A00000, 0x00000002, 0x00000000, 0x8ABE4108)
    e100b325.sys Address 8ABE4108 Base at 8ABD8000, Date Stamp 45ddde2f
    I have no idea what this means or how to remedy it, please help!
    The Minidump file is attached:MINI.zip
    Thanks in advance
  2. #2
    archie123's Avatar
    I Tunes hates Me
    UK
    Win 7 Home Premium 64bit
    uk uk yorkshire
    Re: Blue Screen Problem
    e100b325.sys is an Intel network driver so try reinstalling that first , also update all you drivers including motherboard (chipset drivers)
    It might also be a good idea to update to service pack 2 (your dump file shows your still running 1)
    if you still have problems come back and we can have a closer look at your .dmp file (im a bit pressed for time at th mo )
    and if you have anymore bluscreens pst up your .dmp files
  3. #3
      Thread Starter
    ok updated the service pack, and updated all the drivers one by one. Has been fine and then went 5 mins ago, this time the blue screen showed
    STOP: Ox000000D1 (0x85C06000, 0x00000002, 0x00000000, 0x89FDE108)
    TDI. SYS Address 85C06000 Base At 85C00000 Date Stamp 47919136
    e100b325.sys - Address 89FDE108 Base At 89FD2000, Date Stamp 45ddde2F
    Mini.zip
    Help please
  4. #4
    Old and cranky
    Southeastern CT, USA
    Vista Ultimate x64; Win 7 x64 and x32
    Local Time: 03:26 AM
    usa us connecticut
    The e100b325.sys is associated with your Intel Pro Network Adapter.
    TDI.SYS is also associated with networking.
    I'm not able to analyze minidumps until Thursday or Friday, but if you'd like to have a go at it, follow the instructions here: Diagnosing Bsod's (originally posted 02Oct08) - Vox
  5. #5
    delphin's Avatar
    Eager to learn
    Chennai
    Windows 7
    Local Time: 01:56 PM
    india
    Its clearly a network adapter and driver related problem.
    Bott up in safe mode and rename the e100b325.sys to e100b325.bak. you can find the file in c"\windows\system32 directory
    Restart your computer in normal mode and check. It will create a new file named e100b325.sys.
    If not rename e100b325.bak. to e100b325.sys.
    also check you have any previous verson of the e100b325.sys. file.
    http://www.realtime-vista.com/admini...hadow_copy.htm
  6. #6
      Thread Starter
    System blue screened again about 20 mins after the original BS. Found the file e100....sys renamed it in safe mode, restarted in normal mode and found it had not created a new file so changed it back. Am running Bitdefender for Malware and it has not come up with anything. I am away tomorrow so will try to follow the rather long instructions for analising the mini dump - although it does look a little out of my understanding.
  7. #7
    Old and cranky
    usa us connecticut
    The BSOD instructions appear daunting, but just follow the procedure step-by-step and you'll be able to generate the dump analysis.
    FWIW - this could be a driver issue with the network card, it could be an issue with the BitDefender if you're using the Internet Security version, it can be a hardware problem with your networking card, or it can be a problem with Windows.
  8. #8
      Thread Starter
    hmm, ok i'll give it a go, I am using Bitdefender Internet Security 2009. I'll see what goes as I steadily work through it this morning. Removed 10 malware bits Bitdefender missed though.
  9. #9
      Thread Starter
    no not having any luck here. No MEMORY.DMP file shows up. I have done a search for the file and selected to show hidden files, however I cannot locate it. The minidump file won't open in the debugging tool....Its turning into a bit of a nightmare. Please help. Here's another minidumnp file - worth noting that the service pack didn't complete as the pc blue screened again, so I have safe moded it and am downloading now. when downloading the servicepack in safe mode it stuck on 19% and allowed the mouse to move for a few seconds every 30 seconds. Taskmanager wouldn't open to see if the download was not responding.
    Last edited by crop_circlemaker; 06 Aug 2009 at 05:51 AM. Reason: update on status
  10. #10
    delphin's Avatar
    Eager to learn
    Chennai
    Windows 7
    india
    Quote Originally Posted by crop_circlemaker View Post
    Download and run hijackthis, post the logfile here
Page 1 of 2 12 LastLast
Blue Screen Problem
plz help me --blue screen problem VIJAYMY4RDS Crashes and Debugging 1 10 Mar 2010
Blue Screen Problem saul Crashes and Debugging 2 13 Sep 2009
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Blue Screen problem nastynsh Crashes and Debugging 1 22 Aug 2008
Blue screen problem bubon Vista Games 3 06 Aug 2007
