BSOD Problem
  1. #1
    Junior Member
    Vista x32
    Local Time: 01:25 AM
    BSOD Problem
    Quote Originally Posted by crop_circlemaker View Post
    think I might have found the solution to it, I was doing a search for something and I noticed a rogue Norton 360 file, have used the Norton removal tool and it all seems to be ok for the time being. I suspect it was a clash between Bitdefender and 360? Would this sound about right why it was bluescreening all the time?
    I have Bitdefender and I think I had norton 360 on here...
    Attached is my MiniDump file... hopefully someone can help me out here... I was unable to install the latest driver:
    Minidump file: Free File Hosting Made Simple - MediaFire
    Link to driver: IntelĀ® PRO/100 VE Desktop AdapterĀ Network Adapter Driver for Windows Vista* and Windows Server 2008* I was told to download this but it didnt work please help!
    Thanks.
  2. #2
    Junior Member
    Vista x32
      Thread Starter
    Re: Blue Screen Problem
    Here's a video I just made to show you guys what just happened right now.
    Video - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
  3. #3
    Old and cranky
    Southeastern CT, USA
    Vista Ultimate x64; Win 7 x64 and x32
    usa us connecticut
    Both BSOD's are STOP 0xD1 in your networking drivers.
    Considering the presence of malware, I'd suggest posting over in the security forums to get a clean bill of health: System Security - Vista Forums
    Once that's done, I'd then suggest updating your networking drivers
    If you're still having problems after that, then I'd suggest:
    1 - downloading a free antivirus application (I like Avira Free for 32 bit systems).
    2 - uninstalling the Bit Defender Internet Security
    3 - IMMEDIATELY installing the free antivirus and IMMEDIATELY updating it.
    4 - testing to see if that fixes the issues.
    Should you decide to reinstall the Bit Defender, be sure to download the latest version from their website - and then be sure to remove the free antivirus before installing Bit Defender.
    2 - uninstalling Bit Defender Internet Security
  4. #4
    Junior Member
    Vista x32
      Thread Starter
    Quote Originally Posted by usasma View Post
    Hey Mate,
    Is that information for me or for the gentlemen in the above who's having the same issue? Or, if we're both having the same issue, I guess it applies to both of us?
BSOD Problem problems?
BSoD Problem PLEASE HELP! cavino Crashes and Debugging 6 16 Jan 2010
BSOD Problem chaosrealm93 Crashes and Debugging 8 27 Oct 2009
BSOD problem Darkhorse112 Crashes and Debugging 4 28 Jul 2009
BSOD problem eldergolfer21 Crashes and Debugging 3 27 Jun 2009
BSOD Problem, please help! Chris Vista General 7 12 Jan 2008
