Bluescreen problem not fixed yet =/
Recently i created a post called
BSOD while playing gta 4!help!
I updated all my drivers.
Reinstalled my GTA 4.
Updated to SP 2.
And yet i got BSOD.
IRAL_NOT_LESS_OR_EQUAL
something like that.
i uploaded about 10 minidump file,can you guys check it for me?
I tried to upload before but you guys said its corrupted...is there anyway to zip it on Windows\minidump?
Instead of copying them to desktop and zip it?
I think that is why they are corrupted.
If not,what should i do while i get a bluescreen?Wait?i tried to wait for 30 mins and it has no respone...and it says phy minidump completed and a hella long sentence..ill try to take a picture next time..
  • Mini101909-01.zip
    Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    Lenovo 1440 X 900 60Hz
    1440 X 900
    1TB
Hello martin10522,
These file are showing as corrupt too.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Hello martin10522,
Dang lol.
Is it because i copied them to desktop and zip it?
If so,how could i zip them on Windows\minidump?
Or is it because i restart myself while it is having bluescreen?
If so,what should i do while having bluescreen?
I already waitted til it says physical memory dump complete
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Check your start up and recovery options.
They should look like this, which is the default for Vista.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Type this in the run box: sysdm.cpl
Do not check the auto re-boot as sometimes the error number is useful in most cases.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
kernel memory dump or 64mb?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Here is the numbers..
BCCode: 100000d1
BCP1: 81D43278
BCP2: 0000000A
BCP3: 00000001
BCP4: 90122C39
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
I am using vista sp2,all driver updated.
Did the memtest and got 1300% coverage with 0 errors.
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
so i've read this article
Smart Computing Article - Solve The Blue Screen Of Death
And i think it should be a driver problem
0x0000000A IRQL_NOT_ LESS_OR_EQUAL. A bad driver usually causes this error. Contact the manufacturer of the device that is causing the problem or visit its Web site for an updated or correct driver
but how could i find which driver cause the problem?they are all up to date..
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
bump,could someone help me :(?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Your going to want a kernel dump :)
Also, do you have a video card? Sound card? NIC [Network Interface card] Wireless, wired?
If so go to the manufacture website and update all of your drivers. Problem solved :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
i updated all my driver already..but still
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
On your desktop hit and hold the windows key, and hit R >
the run command will appear >
type sigverif.exe >
let it run as this will verify all of your drivers.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
type sigverif.exe >
ok there is 1 error
entech.sys
what is it?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
type sigverif.exe >
ok there is 1 error
entech.sys
what is it?
entech.sys is related to Futuremark 3dmark05. So do you have that installed on your system?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Acer
    Touchpad
type sigverif.exe >
ok there is 1 error
entech.sys
what is it?
Yes.but is that a driver?lol
My friend gave it to me and he told me it can test my cpu,video card,i got a score of ~11000
So should i uninstall that?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
Also here is my lastest scan result using registeryBooster.
67 Error on user related error,somehow it wont fix it..
I got a few numbers of those bluescreen.should i post them here?
  • latest_scan_results.zip
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
What we need to do is to get a dump file we can analyse, but it's 04.00 here in the UK.
Registrybooster is probably not a good idea, it could well be the reason you are getting BSOD's.
I will be back when i have had some sleep. :sleepy: Hold tight.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Aight.
But thing is that i cannot get the .dmp file.
I tried to zip it,it wont let me to zip it at the minidump files.
I tried to copy it to desktop and zip,it worked,but the .dmp file is corrupted.
I dont know if it is because that i copy the files to desktop and zip it causing it to be corrupted,
Or it is because i restarted myself during bluescreen..
Also,i switched the 64kb option to kenerel dump.
But when i get bluescreen,the physical memory dump keeps at 0 or 20 or 95,should i restart at that point?
And sometimes i get bluescreen and it simply restart itself when i unchecked the auto restart.
Is that strange?
And i dont get the minidump files after chaning it to keneral dump too..should i change it back to 64kb?
And would changing where it saves minidump's folder help?
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    1440 X 900
    1TB
