Hello xmage.
Here are the results of your bugcheck.
STOP 0x00000116: VIDEO_TDR_ERROR
Usual causes: Video driver. Overheating. Bad video card. Bios. Power to card.
Probably caused by : nvlddmkm.sys
As you can see, the most likely culprit is your video card/driver.
Boot into safe mode and use this app to un-install your driver.
Reboot and install the latest driver.
Guru3D - Driver Sweeper
You will also need to check the video cards temperature, and the system temperature too.
Use this free app.
HWMonitor - Download
If anything is overclocked, set it back to default.
You can check to see if there is an update for your Bios, but only update that if nothing else works.
Do you have another card you can try ?.
It wont hurt to check your system files too, they can become damaged after a BSOD.
Open a command prompt as administrator and type
sfc/scannow press enter and let it scan, if errors are found, you will need to scan again, until clean.
Hope this helps, good luck and post your results.
