Need Some Help Please!
danlboggerspot
Hi, first time here, and i need some help. I was updating my iphone to the new 4.0 iOS. And my computer froze, and i waited abt 15 min before i turned it off. After I started it back up, nothing worked! All i can use is my keyboard, my mouse wont move, cant connect to the internet, and no sound. So i decited to try to restore the computer. I went to back it up but it wont detect any USB things, ive tried every port. So could someone here please help me? Or would i have to start off fresh and lose all my stuff on it? Im writing this from my other computer, and was wondering since the messed up one has all the games saved (all are from steam so they will only be able to play on that harddrive so id lose them and abt $100 in games) would there be any problem removing the hard drive from it and my graphics card and moving it into the working one? thanks a billion!
You May Take the Hardrive and place it into a caddy all you need to know is if it is a IDE or a STA HDD. Then you can transfer your stuff.
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
If the keyboard is functional, you can try this.
Ctrl+Esc
Type restore
System Restore should be a highlighted link in the Start menu now.
Pressing Enter at the next three defaults should launch a restore to the "recommended" restore point.
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Ctrl+Esc
Type restore
quick question, would it delete everything? cuz if it does ill try the caddy idea. thanks for the quick answears!!!
Ctrl+Esc
Type restore
None of your files and folders will be touched.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Only System files will be Changed your Personal folders and Files will not be touched
    AMD HD Radeon 6870
    Novatech Night
