Can someone help me with a problem?
I came home after two weeks (hardly ever turn off my pc) and went to start up my pc and everything loaded but was moreless frozen. Clicked on different programs and nothing would load.
I went into safe mode with network access and everything seemed to work fine.
I did a sytem restore to a point right before I left and tried again to load in normal mode and windows green bar would go on across screen then would go black with nothing.
I went back in safe mode and went back farther in sytem restore and now safe mode is black and won't load.
I pulled out the Windows Vista Business and loaded from the Dvd and went into system repair and when I get to the System Recovery Options I get the following message:
This version of System Recovery Options is not compatible with the Version of Windows you are trying to repair. try using a recovery disc that is compatible with this version of windows.
This is the exact disc I installed on this PC.
Any help would be greatly appreciated.
