Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp4_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini090410-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0x8180a000 PsLoadedModuleList = 0x81917930
Debug session time: Sat Sep 4 01:32:33.441 2010 (GMT-4)
System Uptime: 0 days 4:15:55.991
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 124, {0, 845a43f0, f2000018, 6000e0f}
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_SECTION_DESCRIPTOR ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : hardware
Followup: MachineOwner
