Help Vista will not start!
  1. #1
    64
    Local Time: 05:16 PM
    I am running Vista 64 bit on a Toshiba laptop.
    I tried all the advanced startup functions including Startup Repair to no success. I do have the command prompt though.
    I get the windows loading bar then after awhile I get:
    "Stop: c000021q (Fatal System Error)
    The initial session process or system process terminated unexpectedlly with a status of 0x00000000 (0xc0000006 0x00100670)
    System has been shut down"
    Before I turned off the restart upon sys failure, it would just keep restarting and running Startup Repair to no success in a big loop.
    I cannot use sys restore or backup either
    Any ideas?
  2. #2
    The Howling Wolves's Avatar
    Senior Member
    California
    Windows 7 Home Premium 64bit
    Local Time: 04:16 PM
    usa us california
    Re: Help Vista will not start!
    Try this and send report back.
    System Files - SFC Command
  3. #3
    americancritic's Avatar
    Senior Member
    Arizona
    Windows Vista Home Premium 64 bit Sp2
    usa us arizona
    Hello and welcome to the forum...
    It looks and sounds like BSOD...
    If you can is there a way for you to do the following.
    Blue Screen of Death (BSOD) Posting Instructions
  4. #4
    64
      Thread Starter
    Quote Originally Posted by The Howling Wolves View Post
    I tried both sfc /scannow and sfc /verifyonly from the advanced repair options and it said windows resource protection could not start the repair service
  5. #5
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 07:16 PM
    usa us connecticut
    You probably did not start it properly
    Go to search
    type cmd
    right click on cmd when it pops up and then run as administrator
    In the elevated cmd type sfc /scannow
    Elevated Command Prompt
  6. #6
    64
      Thread Starter
    Quote Originally Posted by richc46 View Post
    Go to search
    type cmd
    will not get into OS, using command prompt from the repair menu
  7. #7
    64
      Thread Starter
    Looks like it's a gonner now
  8. #8
    SIW2's Avatar
    Senior Member
    VISTA HOME PREMIUM X64/ 7 x64 / 7x86
    Local Time: 12:16 AM
    Do you mean the HD or the o/s is a gonner?
    If it is the o/s -
    1. If you made a recent system image of some kind - now is the time to restore it.
    OR
    2. You may be able to start up the oem recovery app.
    That should have a method of copying your files off - before restoring the factory image.
  9. #9
    64
      Thread Starter
    Why is the SFC command not working? What am I doing wrong? Also, it asks me something about I want to unmount the volume or something when I use CHKDSK because it is in use?
  10. #10
    SIW2's Avatar
    Senior Member
    Not surprised you are getting those messages.
    Make sure you are running against the correct volume:
    At cmd prompt, type:
    diskpart
    lis vol
    (find the letter for your Vista partition - that might not be the same letter you saw in windows )
    exi.
    Use the letter you found in place of z below:
    sfc /scannow /offbootdir=Z:\ /offwindir=Z:\windows
    after that
    chkdsk Z: /f
    If it asks to unmount, say yes
Page 1 of 2 12 LastLast
Help Vista will not start! problems?
The following boot-start or system-start driver(s) failed to load: i8042prt Petze General Discussion 33 21 Nov 2009
WLAN AutoConfig won't start | Windows Wireless Service won't start.... wheatln2 Network & Sharing 5 25 Jul 2009
VIsta The following boot-start or system-start driver(s) failed to load: tjcrazy Drivers 3 12 Jan 2009
Automatic start of ad-hoc wifi on Vista start-up Hikari Vista networking & sharing 3 30 Apr 2008
Permission needed to start a specific program in the Start Menu Paddy Vista installation & setup 5 12 Aug 2007
