Saved everything I wanted before the attempt to reload Vista, I expected the reload to clear everything from the harddrive
Turn off computer boot during boot press cntrl and then quickly and many times hit F11 If that does not work try the same with f8. It should restore you to factory specs. Your stuff will be lost.
I will give it a try Thanks
Stuck on scroll bar for about 14 hrs, so no change
Sounds like you have hardware problems,
Forum Rules
