| Vista Home Premium 32bit | ntdll.dll problem Hi, I hope I'm posting this in the right section. I have an old version of mavis beacon that I installed on vista and I it worked just fine. But today when I tried to use it, it kept closing. The error is related to the ntdll.dll file. Anyone know why this file would make this keep happen? Problem signature Problem Event Name: APPCRASH Application Name: Mavis.exe Application Version: 1.0.0.1 Application Timestamp: 3592b413 Fault Module Name: ntdll.dll Fault Module Version: 6.0.6001.18000 Fault Module Timestamp: 4791a7a6 Exception Code: c0000005 Exception Offset: 00043387 OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 1033 Additional Information 1: 5c74 Additional Information 2: 08ec40963d098b3286c38157ce556bf4 Additional Information 3: 4b7a Additional Information 4: 3c9848e4c1cc2df25c1240886e3ca19e Extra information about the problem Bucket ID: 691662511 |
| Home Premium 64 | Re: ntdll.dll problem Are you trying to run in compatability mode? |
| Vista Home Premium 32bit | Re: ntdll.dll problem Thanks for replying. No, I'm not running it in a compatibility mode. |
| Win 7 x64 | Re: ntdll.dll problem |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: ntdll.dll problem Hi Niki, What changes were made to your system between the time that the program worked and when it stopped working? If the difference is the SP1 update, then I suspect that is where the problem lies. This is actually the same situation that occured with XP and SP2 and the solution to the problem is to either download a patch (if one is available) or to install a new updated version of the program that is causing problems. Dwarf |
ntdll.dll | Drivers | |||
| My Home Premium 64 Bit Got ntdll.dll Problem!!! | General Discussion | |||
| ntdll.dll error | Vista General | |||
| ntdll.dll fault | Vista General | |||
| Explorer.exe cpu Problem (ntdll.dll!RtIntegerToUnicodeString+0x67) | Vista General | |||
