Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Drivers
Web Cam Issue
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 05-27-2008   #1 (permalink)
Newbie
Vista Home Premium 32bit
gmez is on a distinguished road
  gmez is offline
Web Cam Issue
Hi, I'm new to this forum and this is my first thread. I purchased my laptop, an HP pavilion dv6000 (that's whats printed on the screen), in Nov of 06 and received the Vista upgrade over the summer. As you all are aware of, I had a lot of problems. One that I could never fix was my web cam.
The web cam is built into my screen and worked fine before vista was installed. Once I installed it, it no longer worker. I attempted to download a driver but it never really worked and I kind of forgot about it. Under my Start>All Programs I have two folders with the following in each.
1. HP Pavilion Web cam>HP Pavilion Web cam...the second is also a folder and when clicked on the Start menu closes and that's that.
2. HP Web cam>Uninstall...I've unsuccessfully tried to uninstall and reinstall
Now I really want to use it with skype and can't fix it, can anyone help me?
Any help would be greatly appreciated...THANK YOU!!!!
Giuseppe
Old 05-27-2008   #2 (permalink)
johngalt's Avatar
Antidisestablishmentarian
e x86 MAK, XVista Ultimate x64 MAK, Vista UltimatP x64, XP x86, OpenSolaris 5, Gentoo 2008.1....
3rd Rock
johngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant future
  johngalt is offline
Re: Web Cam Issue
You'll need to find out from HP if there is a Vista driver available for it - more than likely that folder will still have the XP only drivers since your system originally came with XP.
Old 05-28-2008   #3 (permalink)
Daedalus's Avatar
Former 'Axon'
Vista™ Ultimate x64
Turnhout, BE
Daedalus is a splendid one to beholdDaedalus is a splendid one to beholdDaedalus is a splendid one to beholdDaedalus is a splendid one to beholdDaedalus is a splendid one to beholdDaedalus is a splendid one to beholdDaedalus is a splendid one to behold
  Daedalus is offline
Re: Web Cam Issue
Try to go to the Device Manager and uninstall the Webcam completely, then try to find some drivers on the HP site, or maybe across the Internet.
I installed my Logitech QuickCam Chat by uninstalling ALL of it, all drivers, all THINGS leading to it, then installed the last driver off their site, and voilà.
Old 05-29-2008   #4 (permalink)
Newbie
  gmez is offline
Re: Web Cam Issue
Display Modes
Solved The 32-bit RAM Issue CreepinJesus General Discussion 62 08-05-2008 02:23 PM
Windows Vista mouse issue.. Possibly ease of use type issue? Malakie Vista hardware & devices 0 07-10-2008 04:30 PM
Same issue Kirsten Vista print fax & scan 2 05-30-2007 09:36 AM
Monitor issue or full instal issue DaymItzJack Vista installation & setup 2 10-23-2006 07:52 PM
Routre Issue or Vista Issue Gary MCSE Vista General 1 10-15-2006 10:26 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
