Go Back   Vista Forums > Vista Forums > Drivers
Vista - Help on Virtual CD/DVD rom
Closed Thread
Old 06-02-2008   #1 (permalink)
Vista Ultimate x64
Whenever im installing MagicISO or Daemon tools my Vista says tat it has detected a CD/DVD rom but it need the driver to install it, which i cannot find hence the virtual drive is not installed
Someone please tell me how i can solve this problem so that i can use the softwarse.
Old 06-02-2008   #2 (permalink)
Windows Vista x64 Ultimate
Re: Help on Virtual CD/DVD rom
Quote  Quote: Originally Posted by basukinjal View Post
Try re-intalling Daemon tools, or uninstall it and use Alcohol 52% instead (Alcohol 52%_).
Old 06-05-2008   #3 (permalink)
Windows Vista™ Ultimate
Thread closed thanks to SCSIraidGURU and Sidney1st,
Real Good Job Guys.....
Closed Thread
error: Virtual PC could not open the Virtual Machine Network Servicesdriver Virtual PC
Unable to install Virtual Guest Services on virtual machine Virtual Server
RE: Virtual PC could not open the Virtual Machine Network Services driver Virtual PC
Vista Home Premium .. Can't install Virtual Server.. so how do Iautomatically start a Virtual PC without a login? Virtual PC
How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM Virtual Server
