| x64 | problem with esbser.sys I am trying to download a new tune onto a module I purchased for my pickup truck. Every time I try to setup the hard ware, I get a dialog box that says "could not find a part of the path C:\windows\driver~1\usbser.sys Is there anything that I can do? |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: problem with esbser.sys Hi, fsu123187, and welcome to the forums (Be glad, too, as I am a GA Tech fan....) Does it allow you to change the path? If you, replace driver~1 with system32\drivers or SysWOW64\drivers and see if that makes a difference (remember just replace the word drivers - leave C:\windows and usbser.sys alone). |
| x64 | Re: problem with usbser.sys the link for the download installation manual, says if you have problems to use system32, but how would i go about changing it? |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: problem with esbser.sys knowing the module so we can look at it would help - right now I am not even 100% sure what you are trying to do other than copy a file onto some gadget you have... |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| audio problem with my sony vaio laptop and x64 problem | Vista hardware & devices | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
