| vista ultomate 32bit | Vista problem core 2 duo Vista recognizes only one core after tinkering with ACPI driver (Standby didn't work...however...). In Device Manager under Computer it says ACPI-PC, not ACPI Multiprocessor-PC or ACPI x86-based PC... With this ACPI driver Windows is not able to handle multiple cores. When trying to update the driver it doesn't show up the other drivers....however it shows up right in bios setup and it is up to date . |
| VISTA Ultimate in My iMAC Core 2 Duo-- Problem! | Vista hardware & devices | |||
| Vista freezes solid on AMD dual core, single core ok | Vista hardware & devices | |||
| Dual core cpu problem, only one core being found by Vista Ultimate 64 bit | Vista installation & setup | |||
| Intel duel core question with Vista 2nd core not showing being used Help? | Vista General | |||
| Which version support dual core or quad core? | Vista General | |||
