Go Back   Vista Forums > Vista Forums > Drivers
Vista - the problem about wireless lan connecivity
Old 07-31-2008   #1 (permalink)
vista ultimate x64
i have a notebook hpdv2418 pavilion with winvista ultimate x64
but i have problem about connectivity to my home wireless lan
the signal is week and i see "identifying ..." message i have updated
last drivers for my hp i have this problem with both my wireless modem
DLINK2640T and LINKSYS AG200G i hadn't such problem when my hp OS
was winvista 32bit i would be appreciate if any one can help me
Old 07-31-2008   #2 (permalink)
Ultimate x64 SP1
Re: the problem about wireless lan connecivity
Sounds like a driver issue. You may want to try using the windows wireless manager. Or if you are already using that, try using the HP one. Many laptop comes installed with their own wireless connection manager. Sometimes it works better than the built-in windows one, and sometimes it doesn't. Just experiment and see if it helps.
Old 08-01-2008   #3 (permalink)
vista ultimate x64
IN THE NAME OF GOD (TMB&TMM)
DEAR Drubei
I wish you doing well
thank-u so much
for your help & guides
sure! i will consider your recommendation
although it seems such problem is because of win vista x64
in compatibility
have a nice day!
Amir Aug. 12008
wireless problem Network & Sharing
wireless problem Vista networking & sharing
wireless problem Vista General
wireless lan problem Vista networking & sharing
