| ultimate x86 | Problem with internet connection. I use window vista ultimate x86 with NDIS 6.0 realtek network driver. My problem is that whenever I turn on my modem, it takes a significant period of time for the internet to be avaiilble and sometimes,the connection was unstable.My modem is linksys and plugged through ethernet port.Notably, it was faster and more stable when I use dial up model instead (even the internet led changed to red) .Furthermore, when I used the new network driver from window update ,it became impossilbe to connect internet.What is the problem ? |
| Vista Ultimate x64 SP1 | Re: Problem with internet connection. Are we talking about a Linksys modem, a Linksys router or a Linksys modem/router combo? How old is it and when was the last time you upgraded the firmware? |
| ultimate x86 | Re: Problem with internet connection. It is an ADSL modem. I bought it three months ago.I didn't upgrade driver for the network but instead maintain the old one. |
| Vista Ultimate x64 SP1 | Re: Problem with internet connection. So you have an ADSL modem and a Linksys router, right? Which modem and what model Linksys? Modems die. When they do they start the process much like you've described. Just had one die on me last week... luckily I had a spare, but, they do, especially the really cheap ones your ISP hands out. If it's the Linksys router, you could try upgrading the firmware. If it's a bad NIC driver, you could search out an earlier version. If it's the modem, you'll have to either buy one, or get your ISP to send you one. Hit the Windows key and type in cmd, press enter. Type (without quotes) "ping 127.0.0.1". If the loopback test is successful, then the problem isn't your NIC. In that same command prompt, enter in (without quotes) "ipconfig /all" and hit enter. Look for your Default Gateway and write the number down. Ping the default gateway. For example, "ping 192.168.0.1". If this is successful, then it isn't your router; thus, your modem is on it's way to an early grave. |
| Internet Connection Problem | Browsers & Mail | |||
| Problem With Internet Connection...Please Help. | Browsers & Mail | |||
| Problem with my internet connection | Vista networking & sharing | |||
| Internet connection problem | Vista General | |||
| Internet Connection problem | Vista General | |||
