Go Back   Vista Forums > Vista Forums > Drivers
Vista - webcam problem
Old 10-20-2008   #1 (permalink)
Vista Home bit
webcam problem
hey i have bought a gateway M-1628 with a built in webcam and when i open camera assistant software program. it shows nothing the light for the webcam comes on like its on. but it shows no image at all. with the program i can record sound but no video. i uninstalled the driver and reinstalled it and still nothing. just wondering if there have been other problems. i have a Toshiba a while ago with the same program for the webcam just a little different and that one worked at first but just didn't work with messengers and later updated to work. but i can't find new updates of anything for the one i have now.
Old 10-20-2008   #2 (permalink)
Re: webcam problem
Hello JagCustoms87,
I have found this Webcam driver 6.2.218.524 version and Camera Assistant software 1.7.050.1029 version download at Gateway dated 6-11-2008 for both the 32 bit and 64 bit Vista. (last download listed)
Gateway Support Drivers & Downloads
Old 10-20-2008   #3 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: webcam problem
Hi JAGCUSTOMS87 and wlecome to Vista Forums
Have a look here. These are the main Support Documents for your laptop: Gateway Support - 1015584R*Gateway M-1628 Notebook
Old 10-20-2008   #4 (permalink)
Vista Home bit
Re: webcam problem
yeah i been to those already. gateways website is were i redownloaded it and installed it. its the same version i have right now.
Old 10-20-2008   #5 (permalink)
Vista Home bit
Re: webcam problem
well i updated the driver. there was a new one but its still doing the same. the program opens, records audio displays blank. it DOES NOT say no images its just black.
Webcam problem Live Messenger
Hp webcam problem Vista hardware & devices
webcam problem Vista General
WebCam Problem Vista General
Problem with Webcam Vista hardware & devices
