| Vista Home Premium 32bit | cd-rom problems my cd/dvd dive wont read any recordable disks. Windows vista home premium. |
| Vista Ultimate x86 | Re: cd-rom problems Your "My System Specs" are not giving enough information. What make & model is your CD/DVD drive, computer and what type of recordable disks are you trying to read. Not all models of CD/DVD drives will read all types of CD/DVD disks. |
| Vista Home Premium 32bit | Re: cd-rom problems make sure your cd drive can read the type of disc you have in there such as dvd -r or dvd +r etc... also if this persists then you should up date the driver and if that does not work and your cd rom worked before just rollback the driver or do a system restore do this at your own risk but a driver roll back wont hurt the pc lol hope this helped |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| laptop start up problems and problems in general | General Discussion | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
