Go Back   Vista Forums > Vista Forums > Drivers
Vista - GeForce 5200 Problem
Old 12-08-2008   #1 (permalink)
Microsoft® Windows Vista™ 32bit
Hello,
I have installed Vista Ultimate On one of mine computers without service pack 1
When i Install nvidia drivers 96,85 ver Or older After I Get a Blue Screen But I Cant see What It Saying there It closes quickly and Reboots ... After that i Login in Vista But after Some 1 minute aproximatelly it reboots again showing that BlueScreen And i Think It says Somthing about "0x00000001" error But I am Not SURE!!!
So Is there A solution like Installing Service Pack 1 Might solve that ?
:S
Old 12-08-2008   #2 (permalink)
Vista x64 + Windows 7 x64 (Ultimate)
Re: GeForce 5200 Problem
I think others will suggest to install SP1 first as Vista was a little on the iffy side w/o it. My x64 Premium came already with SP1 included this is why I was willing to install it.
I know there is a way for you to disable auto-restart but I am not sure how to do that in Vista so I'll let the gurus chime in on this one since, w/o the error code, they won't be able to help much.
Also, make sure you are using the "Run as Administrator" when installing the new drivers and also make sure you have uninstalled whatever drivers you have now.
Old 12-08-2008   #3 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by AstaLaVista View Post
Same as in XP with an extra click or two,
Start (or Start/Windows key and start typing system and click on System) -> right click Computer and select Properties -> click on Advanced system settings -> Advanced tab and click Settings under Startup and Recovery -> uncheck Automatically restart and OK your way out
Then when you get the BSOD you should get an error message, if you do write it down and then post it back here.
As far as the drivers for that card go from what I can see there is only one available and that is the one you have. Seems that at least as far as the FX5xxx series of cards go, Nvidia has dropped all support for them in Vista. There is a newer driver that supports that series of cards for XP (the 175.19) but those won't work in Vista. It is possible to add the device ID for your card to the newer Vista drivers, but I have a feeling that the driver still won't work with your card. If you want to try doing that let me know and I can walk you through how to add the device ID and try the newer driver(s).
Old 12-09-2008   #4 (permalink)
Ok Thank You.
I just Installed Other version Of Vista , and all Ok!
nvidia GeForce FX 5200 card driver incompatible with GeForce 7600GS ?? - 4 monitors Vista installation & setup
nvidia GeForce FX 5200 problem with Aero Vista hardware & devices
Help.........Issue with GeForce FX 5200 Vista hardware & devices
nVidia GeForce FX 5200 Vista hardware & devices
Nvidia Geforce 5200 Vista hardware & devices
