Go Back   Vista Forums > Vista Forums > Drivers
Vista - DirectX 9.0c problem
Old 01-05-2009   #11 (permalink)
Vista Ultimate x64 SP1
Re: DirectX 9.0c problem
@ Holstarr36 and beaumeister,
Have you guys checked out F03's fourums. Maybe they have some ideas? Also do you have the latest video and souncard drivers installed?
Old 01-05-2009   #12 (permalink)
Vista Home Premium x64
Quote  Quote: Originally Posted by Holstarr36 View Post
I'm coming here because every website and forum so far has been unsuccessful in getting me a solution. My issue is that I cannot update DirectX 9.0c to the November 2008 release. I try to run recent games (Spider-Man WoS, Fallout 3) and get the message that D3dx9_38.dll is not found - which is true, a search does not find it. All these other sites say to just update the DirectX. Ok, I try that. But when I try to update DirectX from either the web update on Microsoft's page or the direct install from either of those disks, I get the error message that the file is in use, even with ZERO programs running and even virus protection shut down. I've tried booting in safe mode, I run the file as admin (I am on the admin account), renamed various DirectX files - all to no avail. Can anyone here give me ANY suggestions as to what to do? These games are worthless, as are any others coming out, as they will all be using this newer version that I can't install/update.
Thank you in advance.
have you tried to install the directx that was supplied with the game(on the disc), the november update only updates directx 10, not directx 9. Try this and i will be surprised if it doesnt work.
Old 01-05-2009   #13 (permalink)
Quote  Quote: Originally Posted by MrNeeds View Post
The answer to your question is in the post.
Old 01-05-2009   #14 (permalink)
Quote  Quote: Originally Posted by beaumeister View Post
Please Help. I can't install fallout 3. I've all the system requirements and more, I have vista 64 bit with a dvdrw drive with labelflash.(might be the problem?) I heard it could be a securom issue, but I can't download the securom patch without having the game already installed. I've tried everything from running fallout as an administarator to copying into a new folder and running it from there. Any help please.
Based on the article I read here - D3dx9_38.dll - D3dx9_38.dll Not Found Error - Missing D3dx9_38.dll - Fix D3dx9_38.dll
I would try updating DX9c with these files - Download details: DirectX 9.0c Redistributable for Software Developers
Good luck
Old 01-05-2009   #15 (permalink)
Quote  Quote: Originally Posted by sygnus21 View Post
ive had a long night, thanks syg
Old 01-06-2009   #16 (permalink)
Vista Home Premium 32bit
Ok, I tried the redistributable - no luck.
Tried again from the disk - no luck.
Checked for update to video drivers (Nvidia 7600GT) - up-to-date (9/28/08 version).
Still a no-go.
At this point, am I looking at a Windows wipe and reinstall? Something is seriously wrong with this.
Old 01-06-2009   #17 (permalink)
Still a no-go.
Have you tried these - Download details: DirectX 9.0c Redistributable for Software Developers?
Old 01-08-2009   #18 (permalink)
vista home premium
fallout 3..has anybody solve the problem missing component 3d3x9_38.dll yet.after downloading? vista home premium 64.directx10,nvidea 9300..-----????
Old 01-11-2009   #19 (permalink)
vista home premium
i cant load directx 9.0c from microsoftdownload and i cant load the directx from the game cause it stops and says that at least one of directx is in use or something how get around this???
Old 01-11-2009   #20 (permalink)
Please look through this entire thread and take note of some of the suggestions. If none of the suggestions here help, look to the game manufature's website.
Also, It would be very helpful to post system specs. Without them, help is limited; whether here, or elsewhere.
Good luck
DirectX Problem General Discussion
Directx 10 problem Gaming
directx problem after crash Graphic cards
Directx 10 problem. Vista Games
Can't run games.directx problem Vista Games
