| Vista Ultimate x64 | Sound Driver (problem) Hey i got some problem with my sound. The problem is when i try too install the drivers for the sound i get an error that says that i recently uninstalled my drivers and need to restart my comp, so i restart and i get the same message and i don't have any drivers for my sound installed. I have tried to reboot windows 3 times w/o any luck. I am using soundmax integrated soundcard, i have tried to install the correct drivers (both the latest and older versions) and i still get tha error. Is there a way to overide the error message and continue the installation? Info on some stuff: Motherboard: P5V-VM DH (not the best motherboard but it worked) OS: Vista Ultimate x64 |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Sound Driver (problem) Hey i got some problem with my sound. The problem is when i try too install the drivers for the sound i get an error that says that i recently uninstalled my drivers and need to restart my comp, so i restart and i get the same message and i don't have any drivers for my sound installed. I have tried to reboot windows 3 times w/o any luck. I am using soundmax integrated soundcard, i have tried to install the correct drivers (both the latest and older versions) and i still get tha error. Is there a way to overide the error message and continue the installation? Info on some stuff: Motherboard: P5V-VM DH (not the best motherboard but it worked) OS: Vista Ultimate x64 Try using this; Guru3D - Driver Sweeper (Setup) download from Guru3D.com I hope this helps Pooch |
| Vista Ultimate x64 | Re: Sound Driver (problem) Still not working ![]() The sound drivers dosn't even show in the list and that's the main problem i have. |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Sound Driver (problem) Okay then try cleaning your registry, CCleaner in registry mode might do the trick CCleaner - Download Pooch |
| Vista Ultimate x64 | Re: Sound Driver (problem) No luck with CCleaner. |
| | #6 (permalink) |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Sound Driver (problem) |
| | #7 (permalink) |
| Vista Ultimate x64 | Re: Sound Driver (problem) I have now tried to reboot my comp with XP but the sound didn't work on XP either so I went back to Vista. I can only see 1 way to get my sound back and that is to buy a new soundcard. Thanks for all your help Pooch! |
| | #8 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Sound Driver (problem) Did you try installing the drivers after performing the CCLeaner and / or System Restore? |
| | #9 (permalink) |
| Vista Ultimate x64 | Re: Sound Driver (problem) My computer couldent find any soundmax driver at all so those programs didn't work, I aslo Rebooted my cumputer with XP to see if there was any Vista issues (that everyone complains about :P) but it always said that I recently uninstalled soundmax and need to restart my computer in order to install the driver (and this was even after a fresh clean Windows install). In the end i had to buy a new soundcard that dosn't use soundmax's drivers and it works great now. |
| Activation problem when updating sound card driver | Vista installation & setup | |||
| Problem with Sound Driver Vista x64 | Sound & Audio | |||
| vista sound driver problem | Vista hardware & devices | |||
| Strange sound driver problem | Vista hardware & devices | |||
| Intel UAA sound driver....problem | Vista hardware & devices | |||
