Go Back   Vista Forums > Vista Forums > Drivers
Vista - CD/DVD ROM issues - please help!!!
Old 03-04-2009   #1 (permalink)
Vista Home Premium
I'm sorry, I'm sure this problem has been reported on more than one occasion but I can't find anything that helps me when browsing through the threads...
Okay, I have no idea about laptops and technical speak so apologies if I sound a bit simple!!
I have a Compaq Presario C500 with a dual cd/dvd rom drive. I am operating on Vista Home Premium (64bit I think).
Yesterday I put the Sims 2 (which is running all expansions except one and is the DVD rom version) in for my neice and the disk would not load up. The drive whirred for a bit like it was starting up, then clicked for a second and then gave up. I had had this game in the night before whilst looking after my neice and it was working just fine. So I tried an audio CD and a short movie DVD and they both worked fine but, despite hours of trying, still had no luck with the game.
I tried it again today and the drive will still not read it only now it will not read any DVD at all, although audio CD's work just fine.
I have checked Device Manager and it is stated that the cd/dvd rom drive and it's controllers are working okay. I uninstalled and reinstalled them anyway but this made no difference. Then I reset BIOS to default state and this made no difference. I then updated all my drivers but nothing is working!!!
I do have custom content installed for the Sims game but after downloading and installing into the game the night before last I loaded it up to check that gameplay was not glitchy and everything was working. So I am assuming it is not that and rather a problem with the drive itself. But what??
I am hoping that I am not going to be told that I need to have the drive replaced and that is is something that has just gone wrong that I may be able to fix myself...
When I turned the laptop on to start the Sims up last night my partner was the last person to use the computer and he had shut it down correctly. Yet when I switched the power on I got a black screen and a menu asking me which operating system I would like to run off... I selected Vista as this is the only option available... Is it likely that this may have something to do with it?? I am just confused as we have had no problems with the drive at all until yesterday and we have never had a screen asking which operating system we would like to use and now the drive will only accept audio cd's...
Any ideas would be most welcomed.
Thanks,
Fiona
Old 03-06-2009   #2 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: CD/DVD ROM issues - please help!!!
Hello Fiona,
Welcome to the forum.
This is not sounding to good, There are two lasers in these drives and it would appear that the laser for DVD's has died on you.
Is your lappy still under warranty? Then take it back. If not any reputable dealer should be able to check and change the drive quite easily, it should also not be to expensive.
I hope this helps
Pooch
DLL Issues Vista performance & maintenance
RC1 to RTM Issues Vista installation & setup
Several Issues... Vista installation & setup
HP issues Vista installation & setup
