| Vista Ultimate x64 | Syst32 problem Hello there, I'm not sure if this is the right place to post this but I cant find anywhere else to put it. If it is in the wrong place please move it to the right section thanks ![]() Anyway, ever since I had reformatted and installed Vista Ultimate x64 again. Everytime I boot into windows i get this error come up with the message The process cannot access the file 'C:\windows\system32\Syst32.exe' because it is being used by another process. Then when i click on "more details" I get this: Quote: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.IOException: The process cannot access the file 'C:\windows\system32\Syst32.exe' because it is being used by another process. at Microsoft.VisualBasic.FileSystem.FileCopy(String Source, String Destination) at Syst32.syst32.Form1_Load(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- Syst32 Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Windows/System32/Syst32.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> It's been bugging me for days and I'm not sure how to fix it Anyone have any ideas as to why this is happening? Also I'm not sure what process is using it and whats trying to use it either and I really dont want to have to reformat my pc again but I will if I have to.Thank you for reading |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Syst32 problem Hello converge, Welcome to the Forum. Is this new? has it just started or is it like this since the install? If it was a bad install........... Re-install If it has just started try a system restore; Tutorials - Vista Forums It might be an idea to scan your system for viruses I hope this helps Pooch |
| Win7x64 | Re: Syst32 problem \windows\system32\syst32.exe is not a standard system file. However, given that it's apparently trying to masquerade as one, given the location and name (anything beginning with "sys" generally puts most people off tampering), there's reason to suspect malware. Unfortunately, a web search suggests that your machine has been compromised: ThreatExpert Report: Backdoor.Win32.IRCBot.gen, W32.Spybot.Worm, W32/Sdbot.worm.gen.a.. Of course, it's possible that you've installed some .Net app that just happens to have the same name as an item of known malware, so further anti-virus scans would be a good idea if you want to be sure. If you're using that PC to earn a living or to work on important documents, the safest option would be to completely flatten it and to start from scratch using known-clean media to reinstall everything. Otherwise, it's impossible to be sure whether the malware left other trojans or similar nasties hidden somewhere. Good luck with it. |
| Vista Ultimate x64 | Re: Syst32 problem Thank you for the replies I'm gonna back up some important files and do a format on my vista and start again just to be on the safe side. |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
