| Vista Home Premium 32bit SP2 | Driver Problem So this morning I checked the computer management and found this warning on the compact flash icon ![]() So I tried the update driver software and I got this ![]() How can I fix it? |
| Windows 7 Ultimate x64 (Vista went bye-bye on this rig) | Re: Driver Problem uninstall the driver (expand the +, right click the item, select uninstall, then click Action > Scan for hardware changes). if that doesn't work, use the disc that came with your motherboard to reinstall the cf drivers. if you have a branded computer, go to the manufacturer's website and look for the most recent drivers. |
| Vista Home Premium 32bit SP2 | Re: Driver Problem uninstall the driver (expand the +, right click the item, select uninstall, then click Action > Scan for hardware changes). if that doesn't work, use the disc that came with your motherboard to reinstall the cf drivers. if you have a branded computer, go to the manufacturer's website and look for the most recent drivers. |
| I have problem starting up Vista - problem with driver | Drivers | |||
| for user that have the driver problem driver. How do we clean inst | Vista installation & setup | |||
| Another problem with CD/DVD driver | Vista hardware & devices | |||
| RE: Vista install problem - Failed to add driver package into driver s | Vista installation & setup | |||
| WLMd crashing problem, possible problem with Vid. Driver?? | Vista General | |||
