network controller???
direwolf
good morning.
I recently replaced my vista 64bit OS with 32bit (for a job) and everything is fine except that I can't go wireless. In Device Manager under "Network Adapters" there is "Other Devices" with a yellow exclamation. Click that on and "network Controller" shows up with the message "This device is not configured correctly. (Code 1)
There is no driver selected for the device information set or element." No matter what I try I can't get it to work. I looked at the pcidev file but can't make sense out of that. Any suggestions as to how to fix this problem would make me eternally grateful.
thanks
    HP-Pavilion FQ550AA-ABA m9426f
    2.40 gigahertz Intel Core2 Quad Q6600
    8GB
    640GB
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
thanks but that didn't work either:(
    8GB
    640GB
