Go Back   Vista Forums > Vista Forums > Drivers
Vista - WIA problem
Old 08-18-2009   #1 (permalink)
vista ultimate 32
WIA problem
I just bought a new Brother printer/scanner and while everything installs correctly, the scanner driver does not. I was on the phone with them and they are telling me its a problem with WIA not allowing the Twain drivers to install properly. I currently do not have any scanners installed and when I go to Scanners in Control Panel, nothing is showing.
I don't know much about this, but is there a way to fix with without having to re-install Vista?
I have Vista Ultimate on a 3 ghz machine with 2.5 ghz ram.
Old 08-19-2009   #2 (permalink)
Windows 7 Ultimate x64
Yes, there should be drivers you can get rid of in Add/Remove applications and device manager. Its not Windows' problem but sloppy drivers. However, what model Brother is it?
Old 08-19-2009   #3 (permalink)
vista ultimate 32
Quote  Quote: Originally Posted by Frostmourne View Post
I found the problem late last night. It seems there was a hidden scanner listed in Device Manager from a failed installation months ago. I un-hid it, deleted it then reinstalled the Brother software and the scanner works fine now.
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
