| Vista Home Premium 32bit | Resolution problem Hi. I don't really know where els to put this so sorry in advance if its in the wrong place. I'm having some problems with my screen colour and resolution atm. Tryed system restore , updating drivers and generaly looking on google for answers but most are unclear at best. Imageshack - myscreen Imageshack - devices These are 2 SS. 1st is what my screen looks like.Although I must say it looks alot worse on my acctual screen. Second Is what I figure the problem is due to them simply not working. NVIDIA GeForce 8300 GS < Windows has stopped this device because it has reported problems. (Code 43) Thats what it says when double clicked on so.. Any help would be much appreciated. |
| Vista 32 win 7 7600 32 bit | Re: Resolution problem Hi. I don't really know where els to put this so sorry in advance if its in the wrong place. I'm having some problems with my screen colour and resolution atm. Tryed system restore , updating drivers and generaly looking on google for answers but most are unclear at best. Imageshack - myscreen Imageshack - devices These are 2 SS. 1st is what my screen looks like.Although I must say it looks alot worse on my acctual screen. Second Is what I figure the problem is due to them simply not working. NVIDIA GeForce 8300 GS < Windows has stopped this device because it has reported problems. (Code 43) Thats what it says when double clicked on so.. Any help would be much appreciated. that should work Let us know if it doesn't Ken |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: Resolution problem There seems to be more to it than just the display driver (although I admit that this needs fixing). Judging by the number of yellow triangles it looks as though you have other issues as well. Have you installed the chipset drivers for your motherboard, and what make and model number is your m/b so that we can give you more advice? As for the graphics driver, you can find details on the latest driver here NVIDIA DRIVERS 190.62 WHQL |
| Vista Home Premium 32bit | Re: Resolution problem Thanks for the replys guys. Its the fact that it happened so randomly I really wasn't sure what the problem was. Not quite sure if this is what ur looking for. ITs about 2 and a half years old. Or round about. Manufacturer : dell Model: Inspiron 530 Processor: Intel(r)Core(tm)2Duo CPU E440 @ 2.00GHz 2.00 GHz Memory(ram): 1.00 GB System type: 32-bit Operating System Edit: D/l that driver didnt seem to help. It seems to be set at default resolution and colour from which I can choose between 800 by 600 , 16 colors , default refresh and anything other than that it goes back to what you see in the screenshot. With this setting the icons are at a better size but its just a lesser version of what you see in the SS. Last edited by mark cul; 09-13-2009 at 09:25 AM.. |
| Vista 32 win 7 7600 32 bit | Re: Resolution problem Hi. I don't really know where els to put this so sorry in advance if its in the wrong place. I'm having some problems with my screen colour and resolution atm. Tryed system restore , updating drivers and generaly looking on google for answers but most are unclear at best. Imageshack - myscreen Imageshack - devices These are 2 SS. 1st is what my screen looks like.Although I must say it looks alot worse on my acctual screen. Second Is what I figure the problem is due to them simply not working. NVIDIA GeForce 8300 GS < Windows has stopped this device because it has reported problems. (Code 43) This driver (video display) has been stopped because it has reported problems Thats what it says when double clicked on so.. Any help would be much appreciated. Good luck ken |
| | #6 (permalink) |
| Windows 7 Ultimate x64 | Re: Resolution problem Uninstall the driver from device manager, reboot into safe mode, run driver cleaner from guru 3d, then reboot again into safe mode and install the newest driver, wheter 32-bit or 64-bit. Then reboot back into windows. Use msinfo32 or Belarc advisor to profile your hardware and update anything else that is outdated. |
| Name resolution problem | Network & Sharing | |||
| Resolution problem | Graphic cards | |||
| Resolution problem | Vista performance & maintenance | |||
| Resolution problem | Vista General | |||
