| Vista | Driver Power State Failure.... I don't know what this really means but I keep getting the blue screen of death that says Driver Power State Failure. I can't be on for more than an hour straight without my laptop crashing and that error comes up. I really have no idea how I would go about fixing this because it is really annoying when I am trying to do things and I don't want to possibly have my laptop die on me. I've only had it for 10 months... |
| Vista 32 win 7 7600 32 bit | Re: Driver Power State Failure.... I don't know what this really means but I keep getting the blue screen of death that says Driver Power State Failure. I can't be on for more than an hour straight without my laptop crashing and that error comes up. I really have no idea how I would go about fixing this because it is really annoying when I am trying to do things and I don't want to possibly have my laptop die on me. I've only had it for 10 months... could you go into c:|windows\minidump, zip the minidump file (*.dmp) and upload it to us. If you need any help with any of it let us know Ken |
| Vista | Re: Driver Power State Failure.... I found it but when I try to upload it it tells me I need to contact the file owner or the administrator for access (?) |
| Vista | Re: Driver Power State Failure.... here we go. please help it seems to be getting worse |
| Vista | Re: Driver Power State Failure.... I checked on my computer and now something happened. It says it could not start so it is running System Repair. I desperately need help to get this fixed. |
| | #6 (permalink) |
| Vista | Re: Driver Power State Failure.... ok i guess system repair did something but right now I don't know if this problem will come up again |
| | #7 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Driver Power State Failure.... NFG its a driver. 02sd.sys. Im looking up what it is a part of now. here is the dump file anaylisys ken Microsoft (R) Windows Debugger Version 6.11.0001.404 X86 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\K\Desktop\Mini092009-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*d:\symbols*Symbol information Executable search path is: Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Personal Built by: 6001.18226.x86fre.vistasp1_gdr.090302-1506 Machine Name: Kernel base = 0x81e1e000 PsLoadedModuleList = 0x81f35c70 Debug session time: Sun Sep 20 00:37:47.200 2009 (GMT-4) System Uptime: 0 days 2:33:54.487 Loading Kernel Symbols ............................................................... ................................................................ ......................................... Loading User Symbols Loading unloaded module list ........... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 9F, {3, 87398030, 87398030, 8766d1d8} *** WARNING: Unable to verify timestamp for o2sd.sys *** ERROR: Module load completed but symbols could not be loaded for o2sd.sys Probably caused by : o2sd.sys Followup: MachineOwner --------- 0: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_POWER_STATE_FAILURE (9f) A driver is causing an inconsistent power state. Arguments: Arg1: 00000003, A device object has been blocking an Irp for too long a time Arg2: 87398030, Physical Device Object of the stack Arg3: 87398030, Functional Device Object of the stack Arg4: 8766d1d8, The blocked IRP Debugging Details: ------------------ DRVPOWERSTATE_SUBCODE: 3 IRP_ADDRESS: 8766d1d8 DEVICE_OBJECT: 87398030 DRIVER_OBJECT: 86e1b8a8 IMAGE_NAME: o2sd.sys DEBUG_FLR_IMAGE_TIMESTAMP: 484e650c MODULE_NAME: o2sd FAULTING_MODULE: 8e949000 o2sd CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0x9F PROCESS_NAME: System CURRENT_IRQL: 2 LAST_CONTROL_TRANSFER: from 81e51b5c to 81eeb0e3 STACK_TEXT: 81f13acc 81e51b5c 0000009f 00000003 87398030 nt!KeBugCheckEx+0x1e 81f13b28 81e516ac 81f13ba0 81f13c50 81f2c401 nt!PopCheckIrpWatchdog+0x1ad 81f13b68 81ed4c40 81f2c4e0 00000000 1a4ea4f4 nt!PopCheckForIdleness+0x343 81f13c88 81ed4800 81f13cd0 8ea45b02 81f13cd8 nt!KiTimerListExpire+0x367 81f13ce8 81ed43c3 00000000 00000000 0009084e nt!KiTimerExpiration+0x22a 81f13d50 81ed2edd 00000000 0000000e 00000000 nt!KiRetireDpcList+0xba 81f13d54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x49 STACK_COMMAND: kb FOLLOWUP_NAME: MachineOwner FAILURE_BUCKET_ID: 0x9F_IMAGE_o2sd.sys BUCKET_ID: 0x9F_IMAGE_o2sd.sys Followup: MachineOwner the only resources a can find on 02sd.sys say its either a driver or it is a virus. Did you do a clean install? do you have a viurs app current and running? have you installed anything other than the OS?? Last edited by zigzag3143; 09-20-2009 at 01:08 PM.. Reason: IMPORTANT VIRUS INFO |
| | #8 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Driver Power State Failure.... Hey there The majority of the references are that it is a valid driver for a sd card reader and that un-installing it and running with a generic driver will stop the BSOD's, and keep the card reader running. I would still do a complete virus scan with a current Anti virus app to be sure Ken |
| | #9 (permalink) |
| Vista | Re: Driver Power State Failure.... Hey there The majority of the references are that it is a valid driver for a sd card reader and that un-installing it and running with a generic driver will stop the BSOD's, and keep the card reader running. I would still do a complete virus scan with a current Anti virus app to be sure Ken |
| | #10 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Driver Power State Failure.... NFG Ok it seems like the fujitsu sd card reader gets the blame on this one. after reading tons of info abt this, and the offending o2sd.sys file, the consensus if to remove the driver and let the generic card reader driver be installed. that will cure the bsod's I hope, but im not sure if the card reader will function 100% with the generic driver Ken |
| Driver State Power Failure | Vista performance & maintenance | |||
| Driver Power State Failure BSOD | Drivers | |||
| Driver State Power Failure While installing Vista x64 Ultimate | Vista General | |||
| Rivatuner64 BSOD Power State Failure | Vista General | |||
| driver power state failure | Vista hardware & devices | |||
