| Vista Home Premium Service Pack 1 | DVD drive problems For some reason my DVD drives don't work. I ran troubleshoot and it says the drivers need updating. So I check for updated drivers and it says that the drivers are up to date. Could anyone provide information to help me resolve this issue. Thank you. |
| vista home premium 32bit | Re: DVD drive problems Hi R3DN3X Try uninstalling the drivers, then reboot PC. |
| Vista Home Premium Service Pack 1 | Re: DVD drive problems Will do thank you very much |
| Vista Home Premium 64bit SP2 | Re: DVD drive problems your dvd drive doesnt need a driver i assume you meant delete it from device manager then reboot next you could try Your CD drive or DVD drive is missing or is not recognized by Windows or other programs |
| Vista Home Premium Service Pack 1 | Re: DVD drive problems I did what you said, deleted it from Device Manager and rebooted. No result, its still in doesn't work. under device status it says. Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) |
| | #6 (permalink) |
| Vista Home Premium 64bit SP2 | Re: DVD drive problems did you try the fix in the link i provided? |
| | #7 (permalink) |
| Vista Home Premium Service Pack 1 | Re: DVD drive problems Yes I did, and with great success. I thank you archie |
| | #8 (permalink) |
| Vista Home Premium 64bit SP2 | Re: DVD drive problems nice one |
| DVD Drive problems | Vista General | |||
| CD Drive Problems | Vista General | |||
| Problems installing Vista on SATA drive as third master drive | Vista installation & setup | |||
| CD/DVD Drive Problems | Vista General | |||
| DVD drive problems | Vista hardware & devices | |||
