[Firstly, I'm sorry if I put this thread into the wrong forum.]
This is an issue which has been bothering me for too long, and now I'm annoyed, so I decided to do something about it. I found this little thingie from Microsoft's website, and so I started to follow the instructions...
Okay. I found it.In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Alright, I found the UpperFilters...In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
Okay, now I deleted the UpperFilters.On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
Oka-- Hey, wait, I can't find that!In the right pane, click LowerFilters.
Aww, shucks.Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
And so I will check the 'Next Steps' section...
And so on. It really didn't help me, unfortunately.If this method did not help you, you might want to use the Microsoft Customer Support Services Web site to find other solutions. Some services that the Microsoft Customer Support Services Web site provides include...
I even tried to use the Fix It -thingamabob, but it didn't help me at all. As you can see...
It's telling me what I already know - The CD/DVD drive isn't detected and the problem isn't fixed.
As you can see, the CD/DVD drive is not where it's supposed to be. It has gone 'poof'. And this is making me crazy! I can't play games or such anymore...
Thanks in advance, any help is loved.
Edit: Oops, I forgot to tell a bit about of my laptop. It's an Acer Aspire 5520, it has Windows Vista Home Premium 32-bit and... That's pretty much all I know. (I feel a bit silly now. Ah well.)
