Vista Twain Driver for a Fujitsu fi-6770a scanner will not load
Phoenix2015
I am attempting to setup a Fijitsu Fi-6770a scanner on my PC running Vista Ultmate 64 Bit.
I have downloaded the Twain Driver From Fijitsu - (Computing Products - Fujitsu Global...) and the driver installs without error by following the instructions at (Computing Products - Fujitsu Global...)
However when I plug the scanner into the PC USB port the OS system can not find the *.inf file for the driver to load on auto detect.
Not sure what I am doing wrong however no Twain Driver is loaded or found. I also ran the setup in Admin mode - still no help.
Any Ideas?
Nobody appears to have this model so best to contact Fujitsu support I would imagine.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
In all likelihood, you need the installation disc to complete the setup. It should also have the Twain driver.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
