Solved Power Management Interface Driver
Jody Thornton
Power User
I was missing a driver for an Unknown Device, and the Hardware ID showed up as:
ACPI\PNP0700
*PNP0700
It's parent device was the Intel 82801EB LPC Interface Controller. So I figured I was missing the Power Management Controller. I look in the drivers included with Vista and all that was on hand was the Intel 82371EB Power Management Controller. I attempted to use this driver, and there are no errors, but I really don't think that's correct.
Interestingly, my last Vista installation did not exhibit this issue. I wonder if anyone who has an HP xw8200 (with ANY OS installed) can tell me what driver is used for this device (most likely the power management controller).
Any assistance is GREATLY appreciated. Thanks. :)
    Windows 8 Pro x64
    HP xw8600 Workstation
    Two Intel Xeon Core2 Quad 3.2 GHz Processors
    Proprietary
    16 GB DDR2 800 MHz
    nVidia Quadro FX 3800 PCI-E
    Realtek HD Audio
    Samsung SyncMaster 213T 21" 4x3 Flat Screen
    1600x1200
    Two Seagate Cheetah 300 GB SAS Disks
    Proprietary
    HP xw8600 Workstation Case
    Two CPU Fans and One Larger Cooling Fan
    PS/2 Keyboard
    Microsoft USB Optical Mouse
    7 mbps
    Storage Interface: Two LSI 3000 SAS Adapters
    Browser: Firefox ESR 102
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Thank you. I will do. I've learned that this is likely the floppy controller which not only did I have disabled on my system, but the drivers were also vLited from my Vista installation DVD
    Windows 8 Pro x64
    Proprietary
    16 GB DDR2 800 MHz
    Realtek HD Audio
    1600x1200
    Proprietary
    PS/2 Keyboard
    7 mbps
So I installed the drivers for the Standard Floppy Controller (from the original Vista DVD). But then it detected a phantom floppy drive. So, to make Device Manager happy, I installed the drivers for the Floppy Disk Drive.
Mind you, the controller is disabled in the bios, there IS NO drive, and the previous installation of Vista (from the same vLited DVD) never asked for it. Nor did Windows XP x64 Edition.
Device Manager is clean now, but it's a tad strange.
    Windows 8 Pro x64
    Proprietary
    16 GB DDR2 800 MHz
    Realtek HD Audio
    1600x1200
    Proprietary
    PS/2 Keyboard
    7 mbps
