Go Back   Vista Forums > Vista Forums > General Discussion
Vista - MAJOR Problem! Help!
Old 12-14-2007   #21 (permalink)
Vista Ultimate X64
Re: MAJOR Problem! Help!
Now I really want to know what the fix is for this myself Sounds like bad hardware or overheating as scrooge pointed out. I think we got all the Guru's here helping you on this one
Raj
Old 12-14-2007   #22 (permalink)
Vista Ultimate x64 SP1
Yes, to reset the BIOS, you have to remove the CMOS battery at let it sit for about 10 minutes. I would then go back into the BIOS and check that your motherboard is detecting everything it should--RAM, HDs--and is running at normal temps.
...And you've probably already checked this, but make sure all your fans are running, and all cables are connected securely.
Old 12-14-2007   #23 (permalink)
Vista Ultimate x64
Ye i reset the BIOS. Didnt change anything! Lol this is rediculous.
Also i got 750w toughpower psu, no chance that im not getting enough power.
Hmm ill try some stuff mentioned here.
Thanks
Also if i dont fix it by monday morning im gona take it to where i got it all from and they said theyll take a look. Even they didnt know what to do :P
Old 12-14-2007   #24 (permalink)
Vista Ultimate X64
How about a guessing game? I choose bad motherboard
Raj
Old 12-15-2007   #25 (permalink)
I agree with Raj. It's sounding more and more like a bad MOBO. Have you tried a different cable for the drive to see if it may be bad?
If you have a spare MOBO laying around, you might use it as a test with your drives.
Old 12-15-2007   #26 (permalink)
Vista Ultimate x64
Na no spare mobo. I can launch the XP cd, i also got Ultimate boot cd. So any ideas?
Old 12-15-2007   #27 (permalink)
Vista Ultima X64
Hi was your computer set up with raid enabled if so you will get a non system disk error when you reset bios because raid defaults to disabled when you reset bios
Hope this helps
Ken
Old 12-15-2007   #28 (permalink)
Vista Ultimate x64
Na no raid
Old 12-15-2007   #29 (permalink)
Vista Ultimate x32
Hmmmm, quite a riddle. 'Bad motherboard' is too broad for the guessing game. So please narrow iyt down to a specific part of the mobo.
How about reflashing the BIOS. If the BIOS is corrupted somehow, it will give these kind of errors. Did you update lately or install new devices?
I guess you checked the CPU fan, Graphics and northbridge temps, in case it might be overheating
Old 12-15-2007   #30 (permalink)
Vista Ultimate x64
Ye temps and fan is fine. And i did reflash the BIOS, that didnt help.
Im taking it to technicians tomorow, so i shall tell how they fixed it Im not taking a no for an answer.
Major system problem General Discussion
A major problem Live Mail
Major Problem, please help System Security
Help need!OS problem Major General Discussion
A MAJOR PROBLEM Vista installation & setup
