Ok. Thanks for your help m8
No problem. Sorry, I couldn't get it solved for ya!
restarted PC and it worked
thanks m8 - nice 1!!!
Did i need to partition both HDDs or can I do that once I get the thing running vista... if so, how?
thanks
Don't know if you found the answer to this yourself, but yes, once you load Vista you can use Disk Management to partition and format the second HDD. To get there, go to the Start menu, right-click on Computer and select Manage from the drop-down. Good luck!
| Similar Threads | ||||
| I have problem starting up Vista - problem with driver | Tomassuver | Drivers | 1 | 15 May 2009 |
| Vista problem, or keyboard problem? | Best | Vista General | 14 | 09 Jan 2009 |
| Generic McAfee Problem Message in Vista Problem Reports | cyberbuff53 | Vista performance & maintenance | 0 | 01 Dec 2007 |
| Vista Sleep Problem / Network Problem | WWJD | Vista networking & sharing | 0 | 11 Oct 2006 |
| Vista Upgrade Problem - Windows Explorer Loop problem | Steve S | Vista installation & setup | 0 | 27 Jun 2006 |
