Go Back   Vista Forums > Vista Forums > General Discussion
Vista Tutorial - System Restore Won't Work
Old 02-29-2008   #1 (permalink)
Newbie
Vista Ultimate 32 bit
First, I have Vista Ultimate 32 bit.
My problem is I can't get the "System Restore" to work. Every time I set it to do a system restore, it appears to go through all the right motions. Then after it shuts down and restarts itself, I get an error message:
"System restore did not complete successfully."
"An unspecified error occurred during system restore."
It goes on to say that the computers settings have not changed.
What's going on? I've tried several different checkpoints including one that I had manually set myself. None of them work, I always get the same error message.
Anybody else ever run into this problem?
Old 02-29-2008   #2 (permalink)
Win7 Ultimate 64bit
Re: System Restore Won't Work
yes I have but I have noticed that System Restore in Vista is not worth much. It's not like xp where you can go back several days or even a week or two. From what I've seen you can only go back about 24 hrs. ... just my 2cents...
FATBOY
Old 02-29-2008   #3 (permalink)
Master
Vista Ultimate 64 bit
Quote  Quote: Originally Posted by 03hdfatboy View Post
This is not true, because I once picked out a restore point way back a month or so ago.
Old 03-02-2008   #4 (permalink)
Win7 Ultimate 64bit
Mine won't do it...never has
Old 03-02-2008   #5 (permalink)
1337 spammer
Windows 7 RC
Somehow a duplicate message got saved. Mods, please delete.
Last edited by .Joe; 03-02-2008 at 12:50 PM.. Reason: Duplicate message got saved somehow.
Old 03-02-2008   #6 (permalink)
1337 spammer
Windows 7 RC
One option would be to do a system repair using the Vista DVD, depending on whats wrong. This may help your situation if restore is not available to you.
Old 03-02-2008   #7 (permalink)
Vista Home Premium 64 bit
I seem to recall that if you are running Norton Anti-virus and the Norton Files under Norton Options are protected the system restore will return that message. I remember having that problem with Windows XP, I don't know if it applies to Vista 32 bit. It does not apply to Vista 64bit which I am running.
Old 07-07-2008   #8 (permalink)
Newbie
vista home premium 32 bit
thank you for that info....my computer is only a month old and it won't do a system restore...it has a free 60 day trial of Nortons on it.....
I will delete that...put on a new AV and see what happens...hopefully I can do a system restore
System Restore doesn't work Vista General
System restore and other system apps do not work Vista General
Does system restore really work? Vista General
System Restore does not work Vista General
System Restore Just Doesn't work Vista performance & maintenance
