Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
Need Serious help on C drive
Thread Tools Display Modes
Old 04-19-2008   #1 (permalink)
  undergrd is offline
When I want to open my C drive, it will prompt me to open my c drive with what program... How come it is like this as I thought when I double click, it will auto open to show the content in my C drive.
Anybody can help? Please...
Old 04-19-2008   #2 (permalink)
DeXtmL's Avatar
Java Desktop Developer
  DeXtmL is offline
Re: Need Serious help on C drive
Probably your system is infected.
Just run a virus scan, that should clean it.
Old 04-19-2008   #3 (permalink)
  undergrd is offline
I scan my pc with AVG free anti virus but nothing was found. Could it be related to any pc settings?
Old 04-20-2008   #4 (permalink)
DeXtmL's Avatar
  DeXtmL is offline
Quote:
undergrd
View Post
Normally, you open your c drive with explorer by default (with a shell cmd handled by OS). it's not likely that you have done any change to System on this critical area (It's related to several registry entries). So my guess is, your system is either damaged by a virus or by someone else who played a trick on u.
If the virus merely modified your explorer registry entries, virtually 90% AV software couldn't detect such virus. You'd better do some system restore. At the best, you can find someone expert at this problem to fix it for you.
Another possibility is (worse) : the virus also placed some malicious code into the hidden file. When you double click your drive icon, your system then starts to seek an appropriate program to open the hidden file generated by the virus. If the system fails to find one, it will give you a prompt dialog asking you to manually choose one. In this case, the virus is probably already cleared, but left some scum in your system which is not recognized as a threat. The solution is also to run restore or find someone with adequate knowledge.
hope this helps
DeXtmL
Old 04-20-2008   #5 (permalink)
  undergrd is offline
Thanks DeXtmL...
I run thru with anti virus but couldnt find anything. Act this pc belongs to my bro and he only bought it few days before my 1st post. So I reali dunno is it virus or some registry fault...
I guess maybe the best method is to reformat...
Display Modes
Complete PC Backup to external hard drive: share the drive? Dick Watson Vista General 1 2 Weeks Ago 02:52 PM
Access XP data drive using Vista Ult (XP drive=slave drive only NO John C (Go Packers!) Vista account administration 0 06-23-2008 02:38 PM
Problems installing Vista on SATA drive as third master drive Marshall Lymer Vista installation & setup 13 03-05-2008 03:44 AM
Vista on the C: drive but System drive is the D: drive - any way to hinnc Vista installation & setup 4 11-15-2007 11:33 AM
Vista maping drive to server 2000 shared drive not recognize user/ Sam Vista networking & sharing 1 11-02-2007 08:18 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
