Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
Print Spooler Problem
Thread Tools Display Modes
Old 05-09-2008   #1 (permalink)
hdbg62's Avatar
  hdbg62 is offline
Thought I'd give this group a try. Have had several hundred of these warnings show up every day since 05/01/08 when I started all over again with everything loaded as from the factory and even before I ever installed my HP printer. Event ID #4, checked it out on MS and it seems I have everything running properly; i.e. both "Remote procedure Call" set to auto in Services. Got another printer showing up in Properties, "Microsoft XPS Document Writer", don't really know what it is or where it came from. If it is a bad registry key can anyone tell me how I can correct this?
Log Name: System
Source: Microsoft-Windows-SpoolerWin32SPL
Date: 5/8/2008 21:34:01
Event ID: 4
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: hdbg62-PC
Description:
The print spooler failed to reopen an existing printer connection because it could not read the configuration information from the registry key S-1-5-18\Printers\Connections. The print spooler could not open the registry key. This can occur if the registry key is corrupt or missing, or if the registry recently became unavailable.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-SpoolerWin32SPL" Guid="{13E8B4F7-4D1C-4F65-95A2-39C6B26A3012}" EventSourceName="Client Side Rendering Spooler" />
<EventID Qualifiers="49152">4</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-05-09T02:34:01.000Z" />
<EventRecordID>18702</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>hdbg62-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">S-1-5-18\Printers\Connections</Data>
</EventData>
</Event>
Old 05-09-2008   #2 (permalink)
hdbg62's Avatar
  hdbg62 is offline
Re: Print Spooler Problem
Guess this one needs to be ignored, did stumble on to prior posts on the subject, albeit with no solutions.
Old 05-09-2008   #3 (permalink)
hdbg62's Avatar
  hdbg62 is offline
Perhaps I found a solution; implemented registry change and will report back:
Spooler warning*~*Downloadpipe.com
Old 05-10-2008   #4 (permalink)
hdbg62's Avatar
  hdbg62 is offline
Seems to work! Whereas I had a dozen or so warning messages appear in Event Viewer everyday, I've had none since I applied the registry change.
Display Modes
Vista 32 bit Print spooler problem? Stu_torrent Vista print fax & scan 0 05-21-2008 06:28 PM
Vista print spooler problem wyocowboy Vista print fax & scan 3 05-04-2008 07:58 AM
print spooler problem with Vista A_N Vista General 2 04-16-2008 10:23 AM
print spooler problem dbl Windows Updates 1 03-29-2008 08:14 PM
print spooler service problem OM Vista General 0 07-10-2007 09:57 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
