br> br> |
| | Thread Tools | Display Modes |
| Newbie Rep Power: 3 ![]() | Start menu problem Hello everyone!! Recently I installed windows for the 21st time...(Yes it is 21) It's all working out but i found a glitch. When i changed the location of my pictures and music to an other location, all of them where working 100%. But then i had to change the letter of the drive they were on. Now when i click on them they don't do anything and if i right-click on it and go to properties it kind of freezes.. A properties window appears but it's almost all white. Any suggestions on how i can reset this?? System restore doesn't work, nor changing the letter at the drive. Thank you in advance. |
| Administrator ![]() Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Start menu problem Hi Dassen_Alex, You can use Option Two in this tutorial to type in the new correct full path with the new drive letter for these folders in the registry instead of the default ones from the tutorial. Personal User Folder - Restore Missing Folder Hope this helps, Shawn |
| Newbie Rep Power: 3 ![]() | Re: Start menu problem Thank u for your time. It's a really god tutorial but my problem is still here. After doing the steps it feels more that the button is stuck than anything else. So the button in the start menu from pictures and music doesn't respond... |
| Administrator ![]() Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Start menu problem You may need to restart again for the changes in the registry to be applied. You can also try unchecking the button in the Start menu Customize area and click ok, then check them again and click ok to see if that will reset them. |
| Newbie Rep Power: 3 ![]() | Re: Start menu problem Done!!!! THANKS!!!! ![]() I am up and running again!!!! Keep up the good work!! |
| | #6 (permalink) |
| Administrator ![]() Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Start menu problem Your welcome Dassen_Alex. I'm glad to hear it is running properly again. Shawn |
| Display Modes | |
| Start button -- start menu Problem | vladsky | Vista General | 1 | 06-01-2008 10:57 AM |
| Start Menu Problem | Ernst - EXE Graphics | Vista General | 3 | 05-13-2008 02:09 PM |
| Start Menu Problem | Ryan | Vista account administration | 0 | 04-16-2007 05:42 PM |
| Default Start Menu option missing from Taskbar & Start Menu properties screen | lmoiola@gmail.com | Vista General | 6 | 03-02-2007 10:37 PM |
| Start Menu Problem in RC1 | =?Utf-8?B?UGVjYTU1?= | Vista General | 0 | 10-05-2006 10:28 PM |
