| Vista Ultimate x64 | Philiphs 900NC/00 Problem Hi, My operating system, Vista Ultimate x64, detects my web-cam [Philiphs 900NC] always as a flash disk. I mean it always shows me "safely remove hardware", which is my web-cam, icon in taskbar . I don't want to see that icon in my taskbar How can I solve this problem? Last edited by hasan_hzl; 07-04-2008 at 08:32 AM.. |
| Windows Vista x64 Ultimate | Re: Philiphs 900NC/00 Problem Hi, My operating system, Vista Ultimate x64, detects my web-cam [Philiphs 900NC] always as a flash disk. I mean it always showss me "safely remove software", which is my web-cam, icon in taskbar . I don't want to see that icon in my taskbar How can I solve this problem?If you have no intention of removing the webcam, then just ignore the "Safely Remove Hardware" option for it. Otherwise, if you do use it, you'll want the SRH option so that you don't just "unplug" the camera without warning, which could lead to further problems with whatever programs may be using it at the time. |
| Vista Ultimate x64 | Re: Philiphs 900NC/00 Problem Thank you for your reply. Anyway it is not a big problem I will leave it there. But when I was using XP, it was not detecting my web-cam like that. Maybe because of the difference btw drivers of the web-cam in XP and in Vista |
| Windows Vista x64 Ultimate | Re: Philiphs 900NC/00 Problem Vista is far more "strict" regarding drivers, which in turn translates to better system stability... |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| fixed unable to delete email problem, now I have new problem | Vista mail | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
