Vista Forums Home Join Vista Forums Webcasts Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
Problems with DPI, resolution, etc
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 07-06-2008   #1 (permalink)
Newbie
Vista Home Premium
Zanderthecat is on a distinguished road
  Zanderthecat is offline
My Vista is about 10 days old and I've gotten into some problems. I tried changing the dpi to 150%, but it changed to 192% and I cant' get it back down. The 'apply' button is beneath the taskbar and not reachable!
Same with the resolution--I made it less, but it is too fuzzy. However, can't get it back because 'OK' button isn't accessible.
In Word, I've lost the regular 'save as' format and it takes me to some screen that won't work.
Please help and thanks. Z
Old 07-06-2008   #2 (permalink)
bassfisher6522's Avatar
Vista Home Premium 32 bit
North Carolina
bassfisher6522 will become famous soon enough
  bassfisher6522 is offline
Re: Problems with DPI, resolution, etc
right click any where on the open desktop. click personalize, then click resolution, change to what ever you want with slider. click apply and OK and thats it.
Old 07-06-2008   #3 (permalink)
Newbie
Vista Home Premium x64
vfxdudeman is on a distinguished road
  vfxdudeman is offline
I've had a similar issue. My HP Updates window, when it popped up after changing my DPI, the text came up off to the side and I couldn't see the OK and Cancel options.
Anyway, I looked around and I can't find any other way to change the DPI other than that window so what you could do is when you're on the window, just hit Tab and try your best to guess which option you're on and then hit Enter. Seems a little silly but it should work lol
Old 07-06-2008   #4 (permalink)
Newbie
Vista Home Premium
Hey, Dudeman, that worked. I'd already tried all of the right click on personalize and like you found--I couldn't access the OK or Apply. I finally just hit Enter and it changed the DPI--then it was easy to do the resolution.
Is this the place for a Word question? SOmehow, when I go to CntlS, instead of the normal Save format--it takes me to a screen entitled Save As; toolbar says computer>OS>Users>Janet>Documents. Then it prompts a File Name, with Save as Type underneath it. Then, Authors; tags; title; subject;manager;company;categories;comments.
I can save there, but it's a lot of trouble. How do I get back to the regular Save As screen?? Thanks again to all.
Old 07-07-2008   #5 (permalink)
Dzomlija's Avatar
Resistance is Futile
Windows Vista x64 Ultimate
South Africa
Dzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond reputeDzomlija has a reputation beyond repute
  Dzomlija is online now
Quote:
Zanderthecat
View Post
Next time you get an issue like this where you can't se the Apply button, try pressing <ALT>+<A>. That is the usual hotkey for Apply...
Old 07-07-2008   #6 (permalink)
johngalt's Avatar
Antidisestablishmentarian
e x86 MAK, XVista Ultimate x64 MAK, Vista UltimatP x64, XP x86, OpenSolaris 5, Gentoo 2008.1....
3rd Rock
johngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant future
  johngalt is offline
Unless it is disabled....
Old 07-08-2008   #7 (permalink)
Chappy's Avatar
Vista Ultimate 64bit
Canada
Chappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud ofChappy has much to be proud of
  Chappy is offline
Hi Zanderthecat
That "is" the normal Save As window for Word 2007. You don't need to add anything in all those other fields and it should default as a Word Document (.docx) so all you really need to do is name it and change the directory you want to save it into if you want.
Once you have named and saved a document, the next time you have it opened, the Ctrl+S keystroke will now do a Save instead of Save As, and it does it without closing the doc.
As usual with anything in Word, even the Save As screen can be complicated with all the options it can give you, but us normal folk rarely need all that outside of a Business environment.
Display Modes
RE: Resolution Problems paradigm Vista hardware & devices 0 05-13-2008 03:04 PM
Resolution Problems Tammy Vista performance & maintenance 2 01-13-2008 12:45 PM
Resolution Problems 16bitGuy Vista performance & maintenance 0 12-27-2007 11:15 AM
Resolution Problems skyzyk Vista performance & maintenance 2 03-19-2007 04:38 PM
Resolution Problems Guy Gordon and the Local 4 News Team Vista hardware & devices 2 02-04-2007 01:56 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
