Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
Motherboard problem.
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 07-17-2008   #1 (permalink)
ultimate 32 bit, premium 32bit, ultimate 64 bit
wysiwyg is a jewel in the roughwysiwyg is a jewel in the roughwysiwyg is a jewel in the roughwysiwyg is a jewel in the rough
  wysiwyg is offline
Fitting a new motherboard, GA-EP35-DS4, all HDD's in situ, just installing CPU, Ram and Graphics card.
First switch on, got to Welcome screen and froze, restarted now all it does is Start Case fan and CPU fan after 2-3 seconds, runs for 10 seconds and switches off, then restarts and keeps going through same procedure, over and over.
On motherboard is a row of 6 LED's showing CPU loading, all six lit each time it starts,????
I've a horrible feeling the CPU is kaput.
Your thoughts and ideas appreciated.
Old 07-17-2008   #2 (permalink)
roy69's Avatar
Geek
Vista home premium 64 bit
uk
roy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond reputeroy69 has a reputation beyond repute
  roy69 is offline
Re: Motherboard problem.
Check the cooling on your cpu first, insure the paste is applied.
Reset your bios to factory defaults.
Remove your hdd`s.
Remove all but one memory module.
Remove sound card.
Remove your graphics card. (use internal)
If your computer boots you know the cpu and motherboard is ok.
install one memory module at a time and reboot. Then install sound card, then 1 hdd at a time.
It may be a hdd problem or power problem.
Old 07-17-2008   #3 (permalink)
  wysiwyg is offline
There is paste on cooler, fitted it myself.
Does shorting CMOS take it back to factory settings.
Use onboard sound,
If remove Graphics card no connection to screen.? how do you know if its booted.?
Old 07-17-2008   #4 (permalink)
z3r010's Avatar
I’m a PC
Vista x64 Ultimate SP1
Manchester, UK
z3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond reputez3r010 has a reputation beyond repute
  z3r010 is online now
Leave the graphics card in as you dont have an onboard, and short the cmos jumper for a second to reset it.
Old 07-17-2008   #5 (permalink)
  wysiwyg is offline
Removed HDD's, shorted Cmos, still the same,
Whats worrying me is the fact that LED's are showing full load on CPU, without HDD's connected.
Its the Phase Led which indicates CPU loading, the higher the loading the more lights are lit, mines showing all lit as soon as you switch on.
Old 07-17-2008   #6 (permalink)
roy69's Avatar
Geek
uk
  roy69 is offline
dont think it is the processor as it would not start.
May be the motherboard or psu shorting out.
Try a different psu if you can as this is the cheapest option.
If the conponents are new and bought from the same place take them back there and get them to test it.
Have you got an internal speaker connected?
If not connect one as you may get the beep codes. This will indicate the problem.
Try pressing the reset switch (not the on off switch). If you have not got a reset switch then short out the reset switch jumper on the motherboard.
Old 07-18-2008   #7 (permalink)
  wysiwyg is offline
Back to square one, removed board, replaced my old one, everything worked perfectly with same equipment.
Ergo Mobo kaput.
Display Modes
Weird motherboard problem fieseler General Discussion 3 06-25-2008 04:00 PM
Motherboard fried, new motherboard, oh oh disk driver issues, blue screen rebooty time! Francis Bacon Vista General 6 06-12-2008 04:31 AM
About Motherboard enriquebeltran Vista hardware & devices 3 04-04-2008 03:59 PM
Motherboard Problem. =?Utf-8?B?QnVsbHk=?= Vista hardware & devices 5 07-22-2006 02:25 PM
Problem in installation of VGA Driver for 845glva motherboard Partha Garai Vista hardware & devices 0 06-25-2006 10:45 PM
Update your Vista Drivers Update Your Vista Drivers Now!!
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
