DVD & CD drive will not read DVD's or CD
Are these blank discs or are they actual movies. What application are you using to actually use the disc. Has this worked in the past? Try to include a little more detail so that we can assist you in the problems you are experiencing.
    Intel Core 2 Duo e8400
    EVGA 680i SLI
    4GB Buffalo Firestix
    EVGA 8800 GT - 2x XFX 8600gt
    Seagate 300gb 7200 rpm
I had the same problem mate. The motor had broke and couldn't spin the disc. Had to call and get a replacement sent out.
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ @3.0GHz
    Asus A8M2N-LA
    4 x 1GB PC2-6400 DDR2-800
    Sapphire HD 4850 512MB GDDR3
    Realtek High Definition ALC883
    Maxtor 500GB Hard Drive SATAII
    Arctic Power 500W PSU
    Logitech UltraFlat Black
    Logitech USB Trackball
    8mb/sec
Does *any* media in the drive work? That is key....
If only a certain *type is not working *burned CDs, burned DVDs, data discs, audio discs, etc) then it is most definitely not the drives problem. If nothing works, then it *may* be a drive problem - but it might also be a *driver* problem....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
