| Vista Home Premium 32bit | Blue Screen problem Files that help describe the problem: C:\WINDOWS\Minidump\Mini082608-01.dmp C:\Users\Hp\AppData\Local\Temp\WER-104099-0.sysdata.xml C:\Users\Hp\AppData\Local\Temp\WEREB28.tmp.version.txt These are the above notifications which are leading problem to my new laptop....i suddenly get a blue..screen saying dumping physical memory. please help me out. My laptop Config - 3 gb ram , 1.83 ghz , 250 gb hard disk, 8400 gsm nvidia graphic card , its hp 6767tx. |
| Vista Home Premium x64 | Re: Blue Screen problem The first thing to try is to go to HP's site and see if all of your drivers are up to date. Run Windows update to make sure it is all up to date. You can also try going to your windows control panel, then go to Problem reports and solutions and if available check for new solutions |
| Vista Ultimate x64 | Re: Blue Screen problem The blue screen of death means your computer crashed. Did you install new hardware recently? If the drivers and solutions don't work, you can try to go to the event viewer. Just type event in the taskbar at start and open the app. Check for errors and write down the error codes and descriptions somewhere. Then go to google (or to microsoft at their online chat), type in the error codes and see what comes up and which solutions. Maybe post the error codes here too. Amplid |
| Vista Home Premium 32bit | Re: Blue Screen problem - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> - <System> <Provider Name="svchost.exe" /> <EventID Qualifiers="0">0</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2008-08-25T19:03:26.000Z" /> <EventRecordID>18282</EventRecordID> <Channel>Application</Channel> <Computer>Hp-PC</Computer> <Security /> </System> - <EventData> <Data>Access violation at address 004527EA in module 'svchost.exe'. Read of address 000002F4</Data> </EventData> </Event> |
| Blue screen problem | General Discussion | |||
| Blue Screen Problem | General Discussion | |||
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| blue screen problem | Vista hardware & devices | |||
| Blue screen problem | Vista Games | |||
