Display Problem?
26pets
My Desktop Display is messed up. First off it doesnt strech across the screen. Second its not the Background I choose. The settings are set to strech the picture. I tryed different backgrounds to see if they work and they dont. Whats wroung with my Display Background?
Is it just the background, or also a bad resolution or something when you're on the internet or so? Because then you should check your graphics drivers... (NOT through winds update!)
Amplid
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Never Mind I solved it =P I had to go in to clean up my files for my picture choices I guess there was a error in one of the files that was selected for the destop I destroyed it and everything restored. Im cleaning up the computer now
Glad you figured it out! Welcome to the forums by the way:party:
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
