Data transfer copy speed
martins77
Hi!
What kind of copy speed can one expect? I get like 20MB/s which seems slow (copy on the same HDD)? (but still faster than copy and past when i got 2MB/s).
I need to change my account name and therefor I need to copy my whole user folder of 90 GB and it takes forever...
Is there something I can do to speed things up?
Regards Martin
    Home made
    AMD 4850e 2.5GHz
    ASUS M3A78-EM
    PC6400 4GB KVR
    Radeon HD 3200 (integrated)
    Realtek ALC1200 (integrated)
    Philip 220SW
    1680x1050 60Hz
    WD GP 500 GB
Hi!
Regards Martin
Hello. Take a look at this tutorials.
Search on for Speed up Hard Drive performance.
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
Alex.
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    Asus G2s Keyboard from Logitech
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    2 MB Wireless Network
don't forget transfer speed also depend on the cache size and RPM of your HDD/pen drive ect
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech G15 (full layout)
    Logitech MX Revolution
Hi and thaks for the reply.
I have loked at the tutorial and adjusted all the setings to maximum performance but still I think it's slow.
I have 4GB of 800MHz ram and a WD GP 7500rpm SATA 16MB so I figure that it would be rather fast (vista performance score on RAM 5.9 and on HDD 5.6 and CPU 5)
Regards Martin (I miss XP in fact I miss 3.11)
If it was not for my girlfrend I would go to Ubuntu (or however it is spelled).
    Home made
    AMD 4850e 2.5GHz
    ASUS M3A78-EM
    PC6400 4GB KVR
    Philip 220SW
    1680x1050 60Hz
    WD GP 500 GB
martins77,
The first thing I will say is that the data transfer should be done by now if you just let it go.
Also keep in mind that the more small files involved, the slower the transfer will be. On my system I can get over 50MB/sec copying a 50GB file from a SATA drive on a motherboard connector to a SATA drive on a PCI RAID controller. Conversely, if I copy 30GB of 30MB files, I only get about 16GB/sec. This gets worse when you copy even smaller files.
No version of Windows has been particularly fast at copying files.
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB)
    1 - Seagate Barracuda 7200.10 (500GB)
Thanks for the info!
S-
I did not quite understand the first sentence (I posted the message a few days ago so yes it is done copying by now..)
I also have a SATA drive (but only one) so I have not set it up to RAID (pointless for one drive?)
When I start the copy I have a speed of 40MB/s but then it rapidly drops to 20MB/s or lower.
I was hoping that having a dual core, 4 X RAM and a faster HDD would speed tings up for med but it does not seem to make any significant difference compared to my older XP system.
Regards Martin
    Home made
    AMD 4850e 2.5GHz
    ASUS M3A78-EM
    PC6400 4GB KVR
    Philip 220SW
    1680x1050 60Hz
    WD GP 500 GB
You could try disabling the Remote Differential Compression although I believe it mainly improves network transfers. Vista still takes ages to simply copy files from one disk to another on my local machine, the speeds you are reporting do not seem excessively slow. Have a look at the tutorials on improving your system performance, in particular those relating to disk drive performance. Also have a look at the properties of your disk drive in device manager and make sure DMA is enabled, although I think your transfer rate would be MUCH slower if it wasn't.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
