| | #21 (permalink) |
| Vista Ultimate | Re: Power Options Corrupt (power plan unavailable) I do have a recent back up but its on cdrom and thats not working........ i guess i may have to locate another pc and save ito n a usb then use it on mine...... I jus wished there was one button i can press that will do the clean reinstall without usb's or cd rom! lol thanks for the quick response!! |
| | #22 (permalink) |
| vista | Re: Power Options Corrupt (power plan unavailable) I have also tried importing the reg keys and no luck. I have run sfc and got the following results attached. There are some error messages but dont know if they affect the power settings? |
| | #23 (permalink) |
| Vista Bussiness x64 PL | Re: Power Options Corrupt (power plan unavailable) Log only say about corrupted tcpmon.ini file.I doubt it really affect power settings,neverless replace this this file +restart.If still no results only System Restore/Repair Install |
| Useful tool for power enthusiasts on the go (advanced power options) | General Discussion | |||
| Power Management/Power Options in Vista | Vista General | |||
| almost no power plan options work | Vista General | |||
| Power Plan Options | Vista account administration | |||
| Power Plan Options | Vista General | |||
