hey! somethings wrong with my explorer. it has to restart every few seconds and i dont know why. i keep on scanning my laptop for a virus but nothing comes up. anyone have an idea as to what the problem could be?
have you gone in the command line and typed sfc /scannow
try it in safe mode....
Fully agree with the above suggestion . Reboot system in Safe Mode and see what happens , If issue does not re occur then try to disable the startup programs and services and then restart system in normal mode. Then try to identify the culprit startup application by enabling the startup apps one by one. If Explorer still crashes in safe mode try to run a spyware scan using SpySweeper .
Which explorer? Window or Internet?
windows explorer. it still happens in safe mode. i did the sfc / scannow in the command promt and a file came up. is it the file causing the problem?
that's probable, hence the suggestion for running sfc /scannow.
Which file did come up? have you written it down?
| Similar Threads | ||||
| Internet Explorer Problem *HELP* Maybe a Javascript problem | SiickOne | Browsers & Mail | 6 | 06 Jan 2009 |
Have A Problem With Explorer.exe please Help!!! | antonyua | General Discussion | 6 | 05 Dec 2008 |
| Vista Internet Explorer/Windows Explorer shortcut problem | mgraham1964 | Vista General | 0 | 27 Aug 2008 |
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Jim Hansen | Vista General | 3 | 16 Dec 2007 |
| Vista Upgrade Problem - Windows Explorer Loop problem | Steve S | Vista installation & setup | 0 | 27 Jun 2006 |
